Results 1 to 10 of 39
Thread: OT maybe? Depends where the funds go. Might be tooling. :D Any guesses?
    Stevens Point, WI
    Default OT maybe? Depends where the funds go. Might be tooling. :D Any guesses?
    So I have been saving my change for a few years. I used to have a smaller container that would fill up within a year or so and be around $100-150ish when I cashed it in. Then I moved up to this container. It is the biggest cheesy ball container you can get. I haven't found any real size on the container other than it boasts "1000 cheesy balls".
    So whats your guess on the amount? To give some idea, when my $100-150 jar was full I dumped it into this container and it filled it maybe half way up the dollar.
    Aug 2008
    Missouri, USA
    How did I know when I saw that jar, that there was going to be a contest involved?
    Nov 2008
    SF East Bay.
    The diameter appears to be about 12 inches. The height appears to be 2.5 feet. That gives us 1.97 cubic feet.
    And that's as far as I can go. I can't tell the difference between the newfangled nickels and the quarters, and heaven help me if silver dollars get thrown into the mix. There's now way I can make a volumetric estimate of the value per cubic inch.
    So, maybe $500.
    Did I win?
    Mar 2008
    If what the op says is accurate $500 is way low.
    I say enough to buy 2 Sandvik carbide boring bars on Amazon!
    Show off --------- hope it covers just enough for your hernia operation and not a dime more
    (it's at least a grand)
    Looks like about $1260 to me.
    Jan 2013
    Alaska
    After close examination I believe it has contains $1189.27. This is base on an average deposit of $119.62. Please don't ask me how I know this.
    Sep 2006
    Big Prairie Mi.
    No idea on the amount in there, but I do know that a quart powerade jug holds just over $80 in mixed coins. I hate having coins and keys in my pocket, always threw the coins in jugs.
    Apr 2014
    Ok... So here goes:
    Looks like the jar is 1' diameter, 1.5' height. So the volume of the jar is pi*r^2*1.5, or 1.17 cu ft, or 8 gallons. 4 quarts in a gallon, so 64 qts.
    64*80=$5120
    Helsinki, Finland, Europe
    Few years? holy moly grease. That is 1859 dollars and 45 cents.
    I have collected my loose change over the last 5 years in a car cigarette tray, maybe 15 coins total in last 5 years
    Not a big fan of cash payments.
    Now if there would be a jar for Ebay receipts that would be different
