Results 1 to 10 of 27
Thread: TIG Welders
    jfsmith Guest
    Post TIG Welders
    I am looking at purchasing a TIG unit. Not sure of which one, so any input would be appreciated.
    Currently I have a Oxy/acetylene torch, a MIG and Stick welders. My work goes from tack welding to serious joining of metals. I probably need to be able to handle 1/2 inch thickness.
    Thanks in advance,
    Jerry
    [This message has been edited by jfsmith (edited 08-11-2004).]
    Feb 2004
    I have a Thermal Arc 185. I love it. But, it's not a 1/2" machine. curious why you want to tig 1/2" anyway. especially when you have a mig allready.
    if you want a new efficient portable machine for precision work it's hard to beat, but a miller dynasty 200 does beat it. (I hear) mostly because it can run on 110 or 220, wheras the TA is 220 only.
    http://www.spaceman613.net/machining/cart.jpg
    jfsmith Guest
    I do a lot of strange welding to create art work out of metal. My MIG is a lighter duty machine. It's a Lincoln Weld Pak 100, a 120VAC welder.
    Jerry
    Dec 2003
    Jerry...for 1/2" thick metal, tig is the LAST thing I'd weld it with. For small, delicate art stuff tig is great but it is a very slow, expensive process when it comes to welding thick material. My opinion...you could probably use a light tig machine for a lot of what you do but you need a better, bigger mig machine for filling 1/2" welds. At one time all I had was a Lincoln 275 tig. I welded everything with it. It cost a fortune and any heavy stuff took forever to weld. I'd never do that again.
    Russ
    I have a Miller Syncrowave 250 at work. It is mainly used on aluminum. For 1/2" steel I would be thinking arc welding.
    Feb 2004
    I have a Miller Syncrowave 250 as well with the pulser unit. I'd love to replace it with a Dynasty 200DX.
    For 1/2" steel check out the Dynasty 300DX TIG and Stick power source.
    http://www.millerwelds.com/products/tig/dynasty_300/
    jfsmith Guest
    I am rethinking the usage, but still looking at TIG units. I may upgrade my MIG to a newer bigger model.
    Jerry
    IOWOLF Guest
    my econotig miller serves me well for gauge thickness only.
    Jul 2002
    Tig machines are great for fusion welding parts that are fit up well and for precision welding of smaller parts. The Synchrowave 180 or bigger is a fine machine. I would use a stick welder or a mig welder for 1/2" thick material.
    Mar 2004
    Sheboygan Falls
    You won't regret buying TIG, but it loses it's advantage on heavy welds.
    Super Dave
    RapidtoCNC.com
