Page 4 of 4 FirstFirst ... 234
Results 31 to 39 of 39
Thread: Supermax Mill
  1. #31
    Apr 2011
    SW Michigan
    Quote Originally Posted by macona View Post
    Supermax did not just make a series II clone, they made the YCM-1 1/2 VA and VS which is a series I clone.
    Did anyone say they only made s series II clone? I just said that was one I had & the one I posted the ad for. I don't know anything about the smaller ones. Sorry
    You can lead people to knowledge but you can't make them think.
    "Lead, follow, or get out of the way." George Patton
    "I don't believe in a government that protects us from ourselves".
    Ronald Reagan
  2. #32
    Mar 2015
    Central Ms
    Lewis Grizzard
  3. #33
    Apr 2011
    SW Michigan
    Lots of better deals, here's one in MS on Ebay item number:302443168304
    Ronald Reagan
  4. #34
    Oct 2002
    Bremerton Washington
    Lotta fitted parts to a turret mill head but in reality they are not much more complicated than a toaster. Any one with mechanic skills and a sense of cleanliness can diagnose and repair a back=gear problem. Take note and pictures.
  5. #35
    Mar 2015
    Central Ms
    Quote Originally Posted by flylo View Post
    I was late seeing your post. It went for $1300 a minute ago.
    Lewis Grizzard
  6. #36
    Jan 2015
    Sandy Oregon
    I have a Supermax Series 1 BP clone. I cant comment on how they compare to BP as this is my first mill.
    NOTED problems: Changing the Hi/Lo speed can be hit/miss sometimes. It wasn't until recently I discovered that if I change into high range the speed changes reliably if I just grab the quil and turn it by hand...drops right into gear.
    I've noticed some table movement when making heavy cuts into steel....MOST likely operator error.
    That's it. The manual lube pump works well, the weighs (dovetail type, not box) seem to be well cut. Its wired for 3 phase so you'll need to spend a little money on a phase converter. This winter I'm going to give a VFD a try.
    The table operates smoothly and tolerances seem plenty tight at least for the ham handed things I make.
    I have a manual for it...sing out if you need me to make you a copy.
  7. #37
    Apr 2011
    SW Michigan
    Quote Originally Posted by Dave C View Post
    Would you have been interested in it? I'll be glad to help find one just PM what you want, want to spend & your e-mail & I'll do my best to find a deal close to you. Nothing better than a Great deal with someone else's money Let me know, Thanks!
    Ronald Reagan
  8. #38
    Aug 2006
    Beaverton, OR
    Thats standard with the back gear on any knee mill, you have to move the spindle till the clutch lines up.
  9. #39
    Mar 2015
    Central Ms
    PM on the way.
    Lewis Grizzard
