Results 1 to 10 of 11
Thread: Inexpensive Rotatory Table Recommendation
    Jul 2017
    Springfield Mo
    Default Inexpensive Rotatory Table Recommendation
    Title says it all, can anybody recommend a decent rotary table that wont break the bank? Im looking for something in the 3-4 inch range, its going on a mini mill. I honestly dont need something super precise, all ill really be doing with this is cutting decorative radii on the ends of piece, no circular hole indexing or any other precision-dependent tasks. Ideally id like to keep the price under $100
    Apr 2011
    SW Michigan
    I bought a never used 24" 4 jaw chuck with the backing plate & wrench for $5 at a local machine shop retiring auction. It was the lot after the lathe it fit, guess the guy wasn't into 4 jaws. I knew the owner & it was on they original skid & had been stored under the lathe cabinet all these years.
    "Lead, follow, or get out of the way."-Thomas Paine
    Ronald Reagan
    East Coast, USA
    I have a feeling you already know what everyone is going to say
    Work hard play hard
    Oregon
    https://www.garagejournal.com/forum/...d.php?t=371729
    The above forum post has a small 4" RT for sale.
    lg
    no neat sig line
    I keep thinking "didn't we do this already?". Then I recall the brief time with the new software when we posted a bunch of stuff.
    Jul 2017
    Springfield Mo
    We did, then it all floated off to neverland
    It'll be back in good time.
    Nov 2008
    SF East Bay.
    I suspect that the database will be reinitialized when they switch us to the new software again. Those 4 days of messages are likely to be lost forever.
    Jan 2014
    Long Island
    While I can't make a specific recommendation for a rotary table, I will recommend you make a nice fixture plate for it. I made a 7 inch fixture plate
    for my 6 inch rotary table:
    This increased the working surface from 28 square inches to 49 square inches. The threaded holes simplify clamping compared to the T-slots in
    the rotary table. By leaving the fixture plate square, the corners provide extra reach for clamping:
    Since this is not intended to be a sacrificial plate always raise your workpiece a little when cutting all the way through as shown above. When
    deciding on what size plate to make, make sure the corner of the plate won't hit the crank on the rotary table or the mills column. A 3 inch
    rotary table provides 7 square inches to work with, a 4 inch fixture plate will provide 16 square inches. With a table that small, every inch
    counts.
    East Coast, USA
    Nicely done Rich!
    Work hard play hard
