Results 1 to 10 of 12
Thread: A question for the gun guru's on rifling
    Sep 2006
    Southwestern Ontario, Canada
    Default A question for the gun guru's on rifling
    do rifling buttons circularly twist themselves to form the helix when pulled through the bore, IE:does the angular shape of the ridges on the button do it or do they need some kind of mechanism to do it.
    Toledo, Ohio
    As far as I know, both methods are used. It would depend on the button design itself as to which method is used. There are also different styles of button depending on whether it is pushed or pulled through the barrel blank.
    Jan 2006
    Scotland Ontario Canada
    You might want to post a question about guns in the gunsmithing forum.
    I am sure that the people who hang out there would be able to help!!
    Mar 2010
    As I understand it, the vast majority utilize the helix angle ground into the button to determine the twist rate. That's why some button rifling shops have a tolerance of plus or minus 1/2" on the specified distance for a complete turn of the rifling. Trying to steer the button with the push or pull rod is problematic since it is a long skinny steel rod and is therefore rather flexible in torsion.
    RWO
    Sep 2012
    Australia
    The buttons self-regulate the twist rate due to the helix ground in to the button. That's why the first inch or so of a button rifled barrel needs to be discarded as it comes off the machine. The 'pusher' is typically free spinning with the button's own motion.
    Jan 2012
    Westlake, Louisiana
    This thread caught my eye as in "I always wondered how they do that." So I looked up rifling buttons. They don't appear to have any ground cutting edges. I'm I correct in that they deform the metal and not cut it? Something akin to rolled threads vs cut threads?
    Definition: Racecar - a device that turns money into noise.
    Quote Originally Posted by browne92 View Post
    Correct.
    It is an economical way to mass produce rifling.
    Single point cut rifling may be slightly better quality for benchrest rifles, but is a slower process and costs a little more.
    Apr 2011
    SW Michigan
    Here's a bunch of you tubes on manual & machine button rifling https://www.youtube.com/results?sear...ifling+process
    "Lead, follow, or get out of the way." George Patton
    Ronald Reagan
    Sep 2006
    Thanks guys. I will take it as a yes, that is pretty much what I hoped for.
    Nov 2003
    Virginia
    I think there is a means of rotating the pull rod as the button is pulled through. While the button does have the "twist" in it, the pull rod is also rotated.
