Page 7 of 10 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 93
Thread: Spline cutting work offered for once-off job
  1. #61
    Jan 2017
    My gut says if you've made the shaft brittle enough that you can't take that bend out in a press it's not going to serve well as an axle shaft at all....
  2. #62
    Quote Originally Posted by JCByrd24 View Post
    I am thinking Cam shafts also need to be straightened and these are extremely brittle, yet there are youtube's of a guy hitting it with a mallet to straighten a few thou out of the thing.
    If he can hit a cam shaft with a mallet I can most likely press 20 thou out of mine.
    However bending in a press will be extremely time consuming also --
    Are these the steps I should follow??? ---
    1. Deflect 0.1"
    2. Relax
    3. Rotate and check run-out if bending took place.
    4. Deflect 0.2"
    5. Relax
    6. Rotate and check run-out if bending took place.
    7. Deflect 0.3"
    8. Relax
    9. Rotate and check run-out if bending took place.
    82. Deflect 2.7"
    83 ***SNAP*** <=== don't want to get here!
  3. #63
    Jan 2017
    It'll go quicker than you think. I've straightened only a couple of shafts in my press but neither took more than a few minutes.
  4. #64
    Sep 2008
    Mid-Michigan USA
    I'm very late to this thread and will admit to not reading it completely.
    I'll also grant this has nothing to do with your question....but.
    I think you picked the wrong material, a better choice would have been 4340M
    aka. 300M. And then had the splines induction hardened not the whole shaft.
    If it's 60 rc all the way through it....not good.
    Sorry
    Dave
  5. #65
    The problem is that the stress-strain curve of hardened D2 ends very quickly -- there is very little plastic range.
    With a soft shaft, if you over-bend it, the worst that can happen is having to flip it over and bend it the opposite way.
    With hardened D2 if you over-bend it, then it will snap.
    This is all my guesswork since I have zero experience working with D2, but below is the stress strain curve -- it ends abruptly.
    Ok, I have ordered V blocks on Amazon.
    Any advise before I leap?
  6. #66
    Quote Originally Posted by Dave P. View Post
    I'm ...
    why "not good"?
  7. #67
    Jan 2013
    Michigan
    Anyone named "paulsheer" ought to be extra careful when using a press to bend hardened steel.
  8. #68
    Mar 2008
    High, Wide and Handsome, Montana
    Yeah, I think hardening the entire shaft was not ideal.
    I would run them as is and see if there is a problem with vibration (or breakage), and go from there. May be a moot issue.
    I didn't see what kind of Jeep, but 100 mph is a stretch, and there is a lot of other wonky stuff going on at hwy speeds on a Jeep.
  9. #69
    Dec 2004
    East Coast, USA
    Yea, is this for a "Jeep" or a "Jeet"
    Work hard play hard
  10. #70
    Apr 2017
    Kelowna BC
    I dont know, we been working on a well designed truck with lift and tilt.
    If it will not drive fine at 90 mph then they failed to meet the goal.
    So far all the versions have been capable of that speed. The latest is a 2017 F 150, and has 44 or 46 inch tires , over 21 Inches of diff clearance, and feels like a stock truck at highway speeds.
    So I say yes, not too much to ask..
