Page 1 of 4 123 ... LastLast
Results 1 to 10 of 191
Thread: Mini-Lathe Improvements, A WIP Thread
Hybrid View
    Jul 2017
    Springfield Mo
    Default Mini-Lathe Improvements, A WIP Thread
    Been saying id do it for a while, and here i am! Im the proud(ish) owner of a Grizzly g8688 lathe, and have always been of the opinion that while it works, it could work a lot better. I know the general opinion is that this class of machine is more a toy than tool and isnt appropriate for much of anything, let alone spending the time necessary to improve, but my opinion is the bones are there, and getting excellent performance (inside what can be expected for this class of machine) is just a matter of putting in some elbow grease.
    First, lets meet the victim:
    Pretty bog standard mini-lathe, almost no modifications. Now, it does work okay at the moment but ive had some issues with it. The first and most obvious is the plastic headstock gears, I broke the low-speed side a while back so that needs to be replaced. Still works in high gear though, barely. Sticking with the headstock, id also like to change out the stock radial bearings with a set of better quality tapered roller bearings. Ive had some serious issues with workpiece deflection, .005" of taper or more on ~1" parts, and im fairly certain half the problem there is just bearing runout/slop.
    The next problem im looking to correct is the movement of the cross and compound slides. Both work, but not particularly well. Im forced to either keep the gibs so tight movement is next to impossible, or loosen the gibs for easy movement but plenty of slop. Compounding the issue is the fact that even when the gibs are locked, theres still an unpleasant lack of rigidity in the setup. Im pretty certain that this particular problem can be attributed to poor contact at the ways, and to correct that ill be trying my hand at scraping in the ways. Backlash on the 2 slides is also a problem. A minimal one to be sure, but one ill be attempting to correct by the addition of Delrin feed-screw nuts.
    The rest of what ill be doing to this lathe is a touch more standard. A carriage lock, carriage stop, and cam-lock tailstock are also on the list, as is a fine powerfeed mechanism separate from the lathe drive train
    Jul 2017
    Springfield Mo
    So, to recap what ill be doing to this lathe:
    -Scraping in the ways of the compound- and cross-slide
    -Delrin nuts for the cross- and compound-slide
    -Replace the plastic headstock gear with a metal one
    -Replace the stock bearings with a set of tapered roller bearings
    That completes what ill be doing to try to address the mechanical accuracy. The separate list to improve usability is:
    -Carriage lock and depth stop
    -Tailstock camlock + improve tailstock alignment
    -Fit fine powerfeed mechanism, separate from the main drivetrain
    I may or may not add to either of these lists. The first thing ill be starting on is scraping in the ways on the slides, so i can get out the most difficult thing first.
    Nov 2008
    SF East Bay.
    It sounds like a good endeavor. I use my 7x12 a lot, and found that adjusting ALL the gibs was important to allow easy, consistent and accurate use. By putting dial indicators on the bed, apron, cross-slide and compound I was able to find out exactly where the movement was.
    May I suggest that before scraping the ways that you straighten and lap the gibs? Sometimes they pick up a banana shape that causes erratic contact.
    I don't worry much about the backlash. The proper technique of infeed is needed whether you have .001 or .010 backlash.
    I look forward to your thread.
    There is a profound difference between spare parts and extra parts.
    Jul 2017
    Springfield Mo
    So, part 1, scraping in the slides! Ill be starting with the compound slide, just cause its the smallest and easiest to replace if i screw up. First things first, a disassembly and cleaning to see what im working with:
    So im going to call the bit on the left the saddle and the bit on the right the base. So, to start with im going to scrape in the bottom of the saddle. Initial bluing:
    Yeah, not too great on the whole 'flatness' thing. In case you cant really see it, theres only blue on the very corners, and not much at that. Few rounds of scraping:
    Getting a little closer. Few more iterations:
    Id say thats a pretty good bearing surface. Better than the start at any rate.
    Jul 2017
    Springfield Mo
    Now, onto the base, but there we hit a problem:
    It shows just a bit in the photo, but the right side is nearly 5 thou lower than the left. Honestly, not sure at this point how im going to correct that, it seems like a little much to attempt to correct via scraping while keeping everything in plane. I might throw it on the mill with a dovetail cutter and just skim it. Of course, the other problem is my present scraper is too thick to scrape into the corners of the dovetails. Both problems for another day!
    Dec 2009
    Stevens Point, WI
    Every time I see or hear of these small lathes I think of this video.
    Clank clank, screech, thunk thunk thunk, "looks pretty good".
    https://www.youtube.com/watch?v=IwJiyFiqxTE
    Mar 2005
    Toronto
    Quote Originally Posted by epicfail48 View Post
    The horizontal surfaces being at different heights doesn't much matter....the do have to be parallel though. You have to make small scrapers to fit in small dovetails and you will need to relieve those dovetails....can't scrape them properly otherwise. Relieve with a heavy old power hacksaw blade or in the mill. Something with a radius is nice, no stress riser (this cutter was originally used for fluting taps and Bertram (P&W)) but not critical, lots are done with straight cutters
    And to put in oil passages and cups while its apart, every machine should have them and its surprising how many don't
  8. #8
    epicfail48,
    This thread has unfortunately gone WAY off topic. Nevertheless, I am interested in your project and am following this thread. Please, continue!
    Sent from my SM-G950U using Tapatalk
  9. #9
    Jul 2017
    Springfield Mo
    Quote Originally Posted by LibbyHillBrewer View Post
    epicfail48,
    Yeah, it took a bit of a left turn, one im sure i contributed to. Rest assured though, i plan on continuing it, just have a lot of projects going on. Need to free up a second to go back to this one!
  10. #10
    Dec 2017
    Bemidji, MN
    I'm glad you started this thread as I'm working with a mini lathe and want to make some improvements on it. Your thread has spurred me to spend time checking and adjusting the gibs on the cross slide more and that helped eliminate the movement but I then got them too tight for easy adjustment so I tweaked the adjustment screws a bit and seem to have easy movement back without the slack I started with. Then I took the saddle off and found one of the screws for the gibs there laying in the chip pan. That might have been one of the problems too. Thank you for the prod to work toward improving my lathe even though I won't likely go nearly as far on that as you.
