Results 1 to 10 of 24
Thread: Strange lathe question.
    Apr 2017
    Kelowna BC
    Default Strange lathe question.
    My lathe is in storage with no power, needs 3ph.
    Might be able to get 110 v single.
    Because my lathe has a very nice gearbox it is very nice for threading, many threads without changing gears, Std and Metric.
    My buddies main lathe cuts only std. He picked up a 14 inch swing metric lathe, I think it cuts a lot of threads, but quite often you are changing gears.
    The tought entered my mind, that if I could power my lathe, with 1 or 2hp, perhaps I could make parts on another lathe, but do the metric threading on mine.. it could be a big help.the la the is 7.5 hp.looks like Kingston or Mazak.
    Maybe not a good idea, but it's there, rather make use of it.
    You CAN get uo to 1 HP, 1.5 HP if the 120V is strong, because several sources sell voltage doubling VFDs that output 230V 3ph from 120V. I think TECO, Hitachi, and Invertek all have them.
    Aug 2010
    Flint, Michigan
    If you can mount a motor that is compatible in mounting needs, certainly it would run strong enough for threading, and actually quite a lot more than that. Unless you use a VFD and 3 phase motor or a DC motor and controller, you would have only one RPM per belt position, but that may have been the case originally.
    Jan 2014
    Edmonton Alberta
    My 18x60 Mazak clone came with 10 hp 3 ph ,I changed over to 5hp 1 ph that I had on hand never a problem.
    Apr 2017
    Kelowna BC
    I was thinking to mount it to outer end of spindle to left of tailstock.
    Jan 2014
    Edmonton Alberta
    If similar to mine you could remove cover where existing motor is and belt drive straight up to driven pulley.There should be room to mount a smaller temporary motor with separate switch.
    Dec 2017
    Bemidji, MN
    A one HP motor would limit the diameter and/or the depth of cut but many lathes are/were powered with much less than that.
    Jul 2001
    Green Bay, WI
    Could be done, but I would not mess with the current drive system.
    Put the lathe in neutral to isolate the current drive.
    Then mount an expanding mandrel in the left side (outboard) of the spindle and have a pulley mounted on it.
    Mount your temporary motor out there and drive it with a V belt .
    Your lead screw drive comes off the spindle so it should be no problem there for threading.
    You may need a double reduction for speed, but don't know the size of your threads. ?
    Rich
    Apr 2017
    Kelowna BC
    Good point the reduction, i like to thread around 150 to 240 rpm.
    Two points, the lathe is easy to setup, easy to use and I am very used to it.
    I can remember cutting threads, say a 5/18 , in 8 minutes. That is mounting tools selecting gearbox settings, and multiple passes.
    Apr 2011
    SW Michigan
    What makes your lathe strange?
    country, in easy stages."
    ~ James Madison
