Results 1 to 10 of 32
Thread: Steel selection advise
    Nov 2017
    Watford, UK
    Default Steel selection advise
    I've been a bit 'enthusiastic' with my vise handle and it's now somewhat banana'd. I've also discovered that haemoglobin isn't an effective lubricant for cheater bars...but that's another story
    Anyway, I'm thinking that it'd be fairly easy to thread the ends of a 12mm rod, screw a ball on each end (no torch, so peening not an easy option) and blam, vise handle. All I have in stock is EN1A which is described as "free cutting mild steel" and according to this table equivalent to 1113 or 1213. I figure this will bend much easier than the original handle and hence, not be of much use.
    I've seen someone making vise handles out of 1144 steel but I can't get that without shipping it in from the US at a cost higher than buying a new vise. I figure it needs to have high tensile strength so as not to bend but still be machineable enough to put a thread on the end. I'm also thinking that if/when it does fail, it would be preferable if it bent rather than snapped. I know that I can get EN3B, EN8, 16, 19, 24 and 36. Can anyone suggest what I need to be looking for in the selection and why please? (The why is so I have more of a clue going forward)
    Many thanks,
    Gareth
    Helsinki, Finland, Europe
    En24 (Temper T) looks good. 34crnimo6 in here or 4340 for amuricans.
    If available you could go for even harder temper grade (X, W?)
    Aug 2007
    Custer WA
    Quote Originally Posted by Cenedd View Post
    Oct 2014
    Could you go to a scrap your and get a drive axle from a front drive car and turn it down. I don't know what they are made from or how hard they are but they shouldn't be much money at a scrap yard.
    Jun 2009
    san jose, ca. usa
    Use an old lug nut wrench
    Jan 2014
    Quote Originally Posted by gambler View Post
    Use an old NAME BRAND lug nut wrench
    Fixed. LOL. I have bent twisted and broken (the welds) cheap lug wrenches.
    Sep 2012
    Australia
    Increasing the diameter of the handle where possible would also significantly increase is resistance to being bent, potentially moreso than increasing the strength of the material it is made from.
    Increasing the diameter from 12 to 13mm reduces the stress in the handle by about 25%. 14mm - 50%.
    Mar 2010
    Threading is not necessary. Loctite 638 or similar is your friend. http://www.loctite.co.uk/loctite-408...=8802627616769
    RWO
    Nov 2017
    Watford, UK
    Michael Edwards: nah, that would imply my over-abundance of muscle was the cause....and it definitely isn't that! It was fine until I managed to find a cheater bar that wasn't made of paper-thin aluminium.
    MattiJ: I only have experience of mild steel and HSS (nothing like polar opposites to broaden your experience). Mild is easy to thread with a carbide insert but I'm not sure the HSS would have been so much fun - turned well enough though. Would the tempered EN24 be soft enough to thread? Not really sure where it would be between the two.
    Gambler/Bob: I'll check out the price of the new bar and look at scavanging mysteralloys if it's too hideous. Thanks for the idea.
    Sun God: thanks, that's worth a check. Could probably widen and clean up the hole in the vise screw for a larger bar. It's a decent enough vise but it's probably import in origin so it could just be that the bar was a bit weak. Stood up to me foolishly (I'd say stubbornly, but I think I crossed the line!) persisting in putting a 90 degree fold in 800-odd mm of 2mm thick 304 stainless with just a Veritas bench vise bender. I guess this is one way of learning how to better spec the materials you're planning to use - half the thickness would have sufficed!
    EN24T is A LOT nicer to thread than mild steel with carbide inserts and reasonable also with hss tools.
    Long holes and tapping needs good and sharp tools but nothing superhuman.
