Results 11 to 20 of 28
Thread: How are these mounted and how can I remove them
    Aug 2009
    The knurled split rings look like they came off of RCBS reloading dies.
    JL................
  2. #12
    Dec 2007
    South Wales
    Have a look if there's a chuck screw in the hole the drill goes, sometimes these get forgotten(!), pair of chuck wedges aka folding wedges, slide together behind chuck, butt one against the side of your vise, tap the other, I find oiling them helps as does polishing the taper, should pop the chuck off its arbour, some are really stubborn, I've had to really hit a few but the chuck was toast anyway, you can press the wedges in the vise to eject, whatever works! (Mind I needed the arbour of one I couldent shift, I cut the chuck away only to find I had left the screw in the chuck in, couldent see it as a spinning drill had done a number on it, hence the warning.
    Mark
    May 2015
    Somerset UK
    Those split threaded collars are a common feature of Albrecht chucks, I'm not sure why.
    I have at the museum, an 0-10mm Albrecht, brand new which was in a box of tools donated to us. Fitted to a MT2, it runs 0.002" tir. You might try your chucks in R8 collets to see what they run like, with different diameters in the jaws, there is no guarantee that fitting directly to an R8 arbor would improve the runout. Actually using R8 collets might result in a shorter assembly in some cases.
  4. #14
    Jun 2009
    san jose, ca. usa
    OK out with it - quite the selection and high quality stuff - so what did you pay?
    I got a bunch of them in a lot, didn't even see most of them buried in a box. I also got stuff that I can't figure out. do you guys get annoyed with these what are they threads?
    Jun 2009
    san jose, ca. usa
    I think I will use them as is. thanks for the info.
  6. #16
    Jan 2010
    Germany
    Those drill chucks are made in 'Germany. I live in Germany. So if A =B and B = Me, Your simplest solution is to send them to me. I will pay the postage because I am a nice guy!
  7. #17
    Dec 2004
    East Coast, USA
    It's better not to ask. If you have to ask, then the answer will probably always result in one of these
    -That's depressing, I wish I got that deal!
    -That's depressing, I wish I could afford that!
    Work hard play hard
  8. #18
    Jun 2009
    san jose, ca. usa
    so true
  9. #19
    Mar 2005
    Toronto
    Quote Originally Posted by gambler View Post
    nope. Often I learn something, occasionally answer.
    My only "what is it threads" dislike is the random guesses.... wait for someone who knows
  10. #20
    Mar 2015
    Central Ms
    You left out the "You suck"
    Lewis Grizzard
