Results 11 to 20 of 21
Thread: Fordillac V-8 engine running, finally
    Jan 2014
    Edmonton Alberta
    Very Nice,your attention to detail is amazing.
  2. #12
    Jul 2009
    Waukesha, WI
    Wow. What a lovely snarl to wake up to on a Sunday morning. I have sent links to all my gear head buddies.
    paul
    ARS W9PCS
    Esto Vigilans
    Remember, just because you can doesn't mean you should...
    but you may have to
    Jan 2010
    I agree with what everyone else said. That is truly a high level of art and fine craftsmanship not seen much anymore. The engine sounds tight (no rattles) and runs smoothly. It is certainly a project to be proud of.
  4. #14
    May 2006
    north bay area
    Love it George, great work as always. Thanks for posting this for us.
    Jan 2006
    Impressive!
  6. #16
    Jan 2003
    Chilliwack, B.C.
    Have to agree with everyone else- that is a fine piece of craftsmanship. Sounds cool too!
  7. #17
    Jun 2012
    San Diego, Ca *** Please let us know where you are from too.
    What can you say ... sounds so good almost want to make it my ringtone. lol.
    I notice that you do have a starter motor on it, Is it an off shelf item and will it actually start the engine. It looks
    perfect, and was just wondering.
    John Titor, when are you.
  8. #18
    Oct 2005
    British Columbia
    Quote Originally Posted by Mike Amick View Post
    George mentions in the video that all of the bolt on components like starter, generator, and fuel pump are non functional but are scale replicas added to enhance the realism of the engine.
    You can also see him use a hand held drill inserted into the bellhousing in order to start the engine.
  9. #19
    Jun 2012
    Thanks Willy ..
    I actually watched the vid, but the list of accomplishments was so long that it must have gotten lost in my brain.
    And I don't know if it would be cheating, but couldn't you put a very powerful off shelf motor inside a replicate casing
    of the starter motor .. and have it actually start the motor. Just think that would add coolness to it.
  10. #20
    May 2003
    Strongsville, Ohio
    A friend has an engine with a starter motor. It's out of scale but works fine. A high rpm motor from an RC car can be used but would need to be geared down considerably to get enough torque to start the engine. The dummy starter on this engine is just way too small to retrofit anything comparable.
    There are some model engines mounted on a box with the starter underneath. A toothed belt transmits rotation to a one-way bearing, which I also use. I have what looks like a clutch assembly bolted to the flywheel and in the clutch is my one-way bearing.
    gbritnell
