Results 1 to 10 of 35
Thread: Okay - when did 1" UNF threads change???
    Apr 2007
    South Texas
    Default Okay - when did 1" UNF threads change???
    I look on all the charts and they all list 1 inch fine threads as 1"-12. So, is ask the boss to get me a couple 1"12 x 4" inch bolts for a project I am finishing and everyone tells us that the thread is 1"-14... So, Just when exactly did this change? and what other changes to the standard have happened?
    I even have the 1"12 tap....
    Helsinki, Finland, Europe
    https://en.wikipedia.org/wiki/Unified_Thread_Standard
    "(*) For many years non-standard 1-inch 14-tpi nuts and bolts have been widely used instead of standard-sized 1-inch 12-tpi fasteners; consequently 1″-14 fasteners are easier to find and less expensive than 1″-12 fasteners. After several decades 1″-14 fasteners have now come to be commonly referred to as "Standard Fine Thread" or "UNF". Though technically incorrect (the UNF standard specifies 1″-12), size 1″-14 is universally accepted as standard for fine-threaded 1-inch fasteners, and "1-inch 14-tpi NF" has become established as a "common use" term, or "a genericized brand name/standard". In other words, the 1″-12 standard has lacked effective enforcement for a long enough time (many decades) to give generic trademark–like status to 1-inch 14-tpi fasteners."
    So it's the standard unstandard
    Timely, was just yesterday working with a 1" 14 and wondering the same thing
    Deep in the Heart of Texas!
    I know what they're doing. They're trying to get us use to finer threads so they can slip-in a metric without us knowing.
    I cut my first M10 x 1.0 the other day.
    Apr 2017
    Kelowna BC
    Now you get to make your own bolts, first make studs, then weld or loctite nut on one end.
    Jul 2003
    This on bite me in the butt a while back customer gave me a print with a 1" Fine hole he didn't list the TPI on the print. So I look on the thread chart and it lists 1" 12 as fine so I get the hole taped. He comes by with the bolts for the project and they don't fit there 1"14. luckley I only did the one of 4 of the parts as we only had the metal to do one at that time. 1" 12 is crossed off all my thread charts you can't find 1" 12 bolts in Portland OR. Wwe were going to make all the parts 1"12 but after a few phone calls we scraped the part. Ken
    May 2015
    Somerset UK
    My UNF thread chart lists 1" and everything above as having 12 tpi. At least up to 3" diameter.
    Feb 2005
    Central Mother Lode. California
    I've never had this come up but I just looked at some of my references. My Starrett wall chart (1999) and my South Bend Lathe wall chart (picked up at IMTS in 1994) show 1"-14 as standard. The South Bend wall chart further shows the 1"-12 as "Special". My _Starrett Book for Student Machinists_, 16 ed., rev. (1975) and my _Machinery's Handbook_ 21st ed., 1979 both list 1"-12 as standard.
    Egad screw threads are fascinating!
    David
    Nov 2002
    Cheshire, CT
    I just checked on the Mc Master web site. In hex head bolts, they only have 1"-14 NF , but they have both 1"-12 and 1"-14 taps. Go figure!
    Craig
    Quote Originally Posted by ckalley View Post
    Craig
    But nuts are available widely in many variations (grade 5/grade8/nyloc/stainless/another stainless/extreme) also in 12 TPI !
    No bolts of any kind but plenty of nuts. Thats NUTS!
    Doesn't make sense (no supprise here, I have given up on threaded parts)
