Results 1 to 10 of 15
Thread: Enco Model 205-6215 Power Feed
    Feb 2018
    NE OK
    Default Enco Model 205-6215 Power Feed
    About 6 months ago I purchased a used Bridgeport that has an Enco model 205-6215, 135 power feed on the X axis. I just got the mill to my home shop and am ready to get it working. Unfortunately, some wise guy cut both the cords off the power feed, possibly by the riggers when the mill was moved from it's former home. I'm reasonably sure one cord is the power and the other went to the limit switch. Do any of you by chance have a wiring diagram for this thing or know where I might find one? This unit was made in Taiwan so odds are good they were also sold with other brands on them. It's also possible the unit is bad and rather that take the time to fix or replace it, the operator cut the cords off and continued to use the X axis in manual feed. A wiring diagram would be most helpful to troubleshoot this thing. Next option is to pull it off, throw it on the bench and see if I can figure it out.
    Thanks in advance for your help,
    Bob
    May 2010
    sierra mountains
    Never looked closely at mine. I would assume the power cord has three conductors.
    The limit switch is simple and would only need two wires.
    Lesson from the wise: once it is working, do not shift directions without letting the motor stop.
    The plastic gear that gets stripped is up around thirty bucks now.
    May 2009
    Canada
    The power cord ought to be straightforward. For 110VAC, I expect you will see three conductors with insulation as follows: green (ground pin), black (copper screw in plug/narrow blade) and white (silver screw in plug/wide blade).
    Here from my comfy chair, I don't immediately have a suggestion for the limit switch. Can check a similar feed later if someone else doesn't provide a definitive answer in the meantime. How many wires do you see for the limit?
    “You learn from mistakes, but success gives you the courage to go on and do even more. ”
    ― Christiaan Barnard
    Feb 2018
    NE OK
    Both cords are 3 conductor.
    May 2009
    Canada
    Any chance of there being three wires for the limit switch: red, blue & black ?
    May 2009
    Canada
    Quote Originally Posted by blasley View Post
    One has a larger black sheath and the three conductors within are heavier gauge w/ green, black & white insulation, yes?
    Sep 2011
    Langley, British Columbia
    There's a good chance that Enco power feeds are made by Align--I know they make others.
    Here's a link to an Align manual in PDF--bet there's little difference if any...
    http://www.elrodmachine.com/PDF/ALig...n%20Manual.pdf
    Keith
    __________________________
    Feb 2018
    NE OK
    That certainly looks very similar. I'll do a little more investigating tomorrow.
    Thanks,
    Bob
    Feb 2018
    NE OK
    Pulled the power feed from the Bridgeport and disassembled it far enough to do some testing. While I was getting continuity through the on/off switch and the circuit breaker, I wasn't getting power out of the circuit board to the motor. While pondering that, it dawned on me the gear was missing from the driven shaft. I think it's time to look for a new power feed. Any suggestions for a decent one that won't break the bank?
    Mar 2013
    West coast of Canada
    Got my Align power feed from Bestline Products in Garden Grove CA. They claim to have lots of parts so may be able to help. I have the manual for mine so could scan and send the circuit diagram it that would help. The limit switch is actually two micro switches so the three wires. There are no color codes that I can see on the wiring diagram and being Chinese made they don't necessarily use the same colors we do in North America.
    Larry
