Results 1 to 10 of 11
Thread: O.T. Do auto companies have a data base for design problems that have been solved
    Feb 2011
    Default O.T. Do auto companies have a data base for design problems that have been solved
    I have a very complex to me 2015 Chevrolet Equinox. It is a fantastic car. Today,the front floor rugs were wet. The air conditioner evaperater drain hose was clogged,probably with mold. St louis has had terrible mold and pollen this year.I jacked the car up and put a thin fexable rubber hose on the drain tube and just blew on it. It unclogged right away. For many people this would be a trip to the dealer ect.. This seems to be a recurring problem that they solve every 5 or 10 years and then forget.It seems like they just try to remember problems and then somebody retires or moves on and they start all over.Edwin Dirnbeck
    Dec 2006
    Rugby, Warwickshire, England
    possible solution:-
    Fit an orifice to limit the flow, then pipe the drain hose to the inlet manifold...
    The possibilities are mindless.
    Mar 2011
    Northern Virginia
    I spent 40 years in GM dealerships as a master tech in various certifying orgs. No corporate memory what so ever. Every new engineer has to justify his existance so he/she starts with a clean sheet of paper. And the manufacturers design cars to assemble not repair, the bastiges!
    Joe
    Jan 2014
    In the desert
    One condensate problem (smell) was solved on my 2012 work truck by programming an after shut down fan run interval. Truck had the problem from new until I told them to fix it or take the truck back.
    Deep in the Heart of Texas!
    When was the last time you changed the cabin filter? Also, only use the "MAX" setting of the AC for a short time. Once the car (cabin) had cooled down, switch the AC over to the Fresh-Air setting. Both the filter and fresh air help control mold.
    May 2013
    UK, near London
    Blocked tubes common on self defrosting fridges, condensing boilers, air conditioners, and my MGBGT fresh air inlet.
    Jun 2009
    san jose, ca. usa
    just for others info, the best thing for clogged condenser drains is a zip tie. wont hurt the evaporator.
    Central Ohio
    They evidentally have a file of things that do not work, They mine it for ideas that might have been forgotten and reintroduce them again. We are about due for a Corvair, Pinto, Vega, or Dodge of Your choice.
    mark costello-Low speed steel
    Jan 2014
    Long Island, N.Y.
    Quote Originally Posted by Joe Rogers View Post
    Joe
    I wonder how many car models have had recalls for fuel line routing issues. If only the designers had guidelines like avoid chafing, avoid sharp
    edges, avoid hot surfaces like exhaust components, avoid kinking, and avoid excessive flexing should cover a lot of the problems.
    Feb 2005
    Ohio
    What about the database of service bulletins? Sounds like what you are asking about. These are factory repair solutions issued as they come up and are corrected. Heck, I can get them for my 1957 Triumph, someone has compiled them into a book.
    Dennis
