Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: clock winding ratchet
    Oct 2001
    simpsonville s c
    Default clock winding ratchet
    how do I build one, the one i need has 14 div. with id of 1.000. i know this is not like a gear like this https://www.ebay.com/itm/11mm-REPLAC...-/400676485932
    So how is it done and what cutter I have never made one of these
    Aug 2004
    Sunny So Cal
    How bout this and a dividing head? You can get them in various angles. Could even use an inexpensive router bit. JR
    dovetail cutter
    Oct 2001
    simpsonville s c
    get just got that now how do i get 14 in to 360 = 25.7142857 for the div. I never have on this or a gear
    Aug 2004
    Sunny So Cal
    Quote Originally Posted by Brett Hurt View Post
    Can you plot that out on paper via the computer and use that as a guide with the dividing head? JR
    Aug 2004
    Sunny So Cal
    Quote Originally Posted by JRouche View Post
    May 2002
    Do you even have a dividing head? If not, what?
    14 divisions.
    A spin index, which has 360 divisions will not come out even (360/14 = 25.71...). But a winding ratchet does not have to be very precise so you could round to the nearest degree and it would work. In fact you would be hard pressed to notice the differences. Here is a table you could follow. The worst error is 0.43 degree.
    0
    26
    51
    77
    103
    129
    154
    180
    206
    231
    257
    283
    309
    334
    360
    If you have an indexing head or rotary table that has any gear ratio that is even (1:40 or 1:90 are common ones), then you can use any hole circle that has any multiple of 7 holes: 7, 14, 21, 28, etc. If you can provide the details, I/we can advise on turns and holes per division.
    If you have neither of the above, you can use a paper scale as suggested above. Any CAD program can compose and print a suitable scale. Again, for a winding ratchet, a lot of precision is not really needed.
    Make it fit.
    Dec 2009
    Farmington Hills, MI
    We are over - thinking this ! It's a simple ratchet not a cog wheel and in brass at that. How about a pair of dividers and a file.
    Joe B
  8. #8
    May 2002
    Yep, in fact that is how some of the old clock/watch makers would have done it. Scratch a circle. Set the dividers with a good (or bad) guess. Step around that circle and observe the error. Make a correction and try again. Repeat until you can not see any further error.
    Not super precise, but it will work.
    Stop worrying about it and just do it.
    Quote Originally Posted by JoeCB View Post
    Joe B
    Make it fit.
  9. #9
    Aug 2004
    Sunny So Cal
    That is actually a pretty precise way to map out a bolt circle.
    I was gonna suggest that but it seemed like Brett wanted to use another method. JR
  10. #10
    Dec 2017
    Bemidji, MN
    https://www.youtube.com/watch?v=-we6ORrJgUI
    Most spring winding ratchets don't have to be terribly precise. I've made one of these and used it to make plastic gears for my mini mill and mini lathe. It should be pretty easy to adapt it to a ratchet wheel using just a straight milling cutter set to mid point on the blank. Make shallow cut, turn blank, make next cut.
