Page 8 of 15 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 149
Thread: Double acting Double cylinder Oscillator
  1. #71
    Jan 2010
    I would suggest an 1/8" sheet of Delrin pinned in place rather than bronze or cast iron. The Delrin (or Acetal) won't wear the Aluminum, and the Aluminum won't wear the Delrin. The Delrin will slide freely enough that you can have a fairly tight joint that will still move easily.
  2. #72
    Mar 2008
    Barrie, Ontario, Canada
    See post #70 for video of engine running.---Brian
    Jan 2010
    Very nice! The video was put on while I was typing. Looks good.
  4. #74
    Mar 2008
    After 3/4 of an hour running, 80% of the stiffness is gone. Any residual friction is easily overcome by the power of the engine. I thought it would be like that, but I'm never sure until I've run a new engine for a while.
    Aug 2015
    Regina,Sask
    A really nice little engine, Brian. I have enjoyed your build.
    Glenn Bird
  6. #76
    Jan 2015
    South Central Louisiana USA
    Great job! I might have to build one of those before too long. Thanks
  7. #77
    Dec 2015
    Chilliwack, BC, Canada
    It looks and sounds great Brian. I'm going to bet it has a really nice beat to it once you can slow it down a bit too.
  8. #78
    Nov 2011
    A fine running engine. Sounds just like a tin lizzy. I still want to see you paint one just like the cad drawing.
  9. #79
    Mar 2008
    As promised, here is the final video of the double cylinder oscillating engine. Please note that I misspoke in the voice-over and said it has a 2 3/4" stroke. That was wrong.--It has a 1 3/4" stroke.---Brian
    https://www.youtube.com/watch?v=1id_...ature=youtu.be
    Mar 2008
    Is there a "tried and true" method of making a simple air reversing valve. On my current engine I have two "out" ports which the exhaust comes out of, and two "in" ports where the air pressure goes in. My intake manifold feeds air to the top two ports and allows the bottom two ports to exhaust to atmosphere. I was laying in bed last night thinking about a "reversing handle" on the manifold which would allow me to reverse the engine direction. I have it designed in my head, but it is a bit crude. If a current design exists for this, I would happily copy it.
