Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Marking barrels with caliber designation
    Feb 2014
    Hmm, I'll have to look into those, thanks!
  2. #12
    Nov 2003
    Virginia
    I have the inexpensive etchomatic, and with some practice, a very nice lettering can be done. I use the blue waxy type paper they sell, and type it out on a cheap electric type writer. I cut the typed letters to a strip, then tape the appear where I want it, top and bottom. I first use the supplied diode to get an "etch", then take the diode off and use the felt direct on the paper. Let it soak there for a minute or so, and you're done. Nice deep letters. You have to keeep the paper in place.
    Apr 2018
    Default Registering hand stamps
    Quote Originally Posted by Forestgnome View Post
    Metal stamps and a hammer.
    If you are going to use hand stamps and a hammer, make yourself a simple stamp guide. Make a bracket to bolt/clamp onto your mill quill. Then weld on a block of steel that you can mill a verticle slot that fits the size stamps you have. hold the stamp in the slot with your thumb and tap with hammer. Crank the right amount travel on the milling table and stamp the next number. It looks like you did it with a typewriter.
  4. #14
    Dec 2016
    I take the barrel to a trophy shop & have them engrave the caliber on it.
    Apr 2011
    South Louisiana
  6. #16
    Sep 2009
    Sacramento, CA
    Quote Originally Posted by Rock View Post
    That's the way I do it. That way you can make practice runs and figure out the spacing. You can also make a printout of what you're going to stamp and tape it on the piece for correct kerning. For 1/16" stamps I use 7pt font if I remember correctly.
  7. #17
    Jul 2014
    Cumberland, Maine
    Perhaps a pantograph?
