Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: A Few Notes On Two Speed Induction Motors
    Sep 2017
    Poulsbo, WA
    Here is the Data Plate from the motor
    I read it as
    5 HP, 3390 RPM, 13.2 A
    3 HP, 1710 RPN, 10.2 A
    Be_Zero_Be
  2. #12
    Nov 2007
    Woodinville, WA
    Quote Originally Posted by Noitoen View Post
    In his case, low speed 5hp high speed 3hp.
    no... other way around. Constant torque means rpm increases with speed. No quite linear, but close enough.
    Jan 2004
    Missouri
    no... other way around. Constant torque means POWER increases with speed. No quite linear, but close enough.
    Fixed it
    Nov 2007
    Woodinville, WA
    lol.. thanks and it's even later for you than me!..
    ...but heck rpm does increase with speed
    Oct 2013
    Setubal, Portugal
    That plate is stamped out wrong (on purpose ). It's true that the motor draws more current in the high speed but the real power at the shaft is less. It draws more current due to poor efficiency. I've been in the motor rewinding business for many years and repaired a lot of these motors for construction cranes.
    Helder Ferreira
    Setúbal, Portugal
  6. #16
    Nov 2007
    Woodinville, WA
    We will just disagree then.
    Were the motors you worked on were wound for constant HP and not constant torque? I can see why a crane would want a constant HP motor (same lifting capacity at different speeds). The OP motor is constant torque and very common in machine tool applications.
  7. #17
    Dec 2016
    Helsinki, Finland, Europe
    The 2 most common Dahlander motor windings round here are constant torque and quadratic torque.
    constant torque one would make 50% power at half speed
    quadratic torque ones are used with fans and centrifugal pumps and make only 25% of power at half speed.
    Constant HP 2-speed motors are rare beasts.
    For example:
    http://lst.fi/webshop/media/M3000_Aluminium.pdf
    Fan-drive 2-speed motors start at page 31 and constant torque ones at page 35
