Results 1 to 10 of 31
Thread: Looking for a rotary joint, no idea what its called :)
    Aug 2007
    Hertfordshire, England
    Default Looking for a rotary joint, no idea what its called :)
    I have a shaft that rotates slowly, about 30rpm, I need to pull that shaft in and out with an air cylinder.
    Any idea what that joint or coupling might be called??
    Searching but cant get the right name, i'm sure its an available part??
    Sep 2017
    Poulsbo, WA
    Swivel ??
    Ball Joint ??
    Universal Joint ??
    Wobbly-Clyde ??
    Be_Zero_Be
    Oct 2013
    Setubal, Portugal
    could use s gearbox type fork. Easy to make, a groove in the shaft and the fork on the cylinder
    Helder Ferreira
    Setúbal, Portugal
    Aug 2007
    Yes it will need to be something like that, i just rang SMC pneumatics sales and there is no off-the-shelf coupling that takes rotary motion as well as lateral.
    Fork/groove might work ok though.
    Jun 2007
    Anderson SC
    Look at "rotary unions" IF I follow your description correctly
    Jan 2002
    Huntsville Ala
    "linear actuator" is one term, but I don't know if that could encompass rotary motion.
    Aug 2007
    Thanks all, rotary union bought up some interesting stuff but that term seems to mean passing fluid through the rotary joint - we only need a mechanical joint.
    Linear actuator brings up actual motion devices i'm afraid
    Maybe linear rotary joint, will check
    Aug 2013
    Schwenksville, PA
    spline drive?
    Aug 2007
    No, that would transmit the rotation - we need to pull/push the rotating shaft with a stationary shaft
    You mean like a bearing block that the inner race grubscrew's or fixes onto the rotating shaft, and the block flange attaches the stationary shaft?
    If there's a commercial part especially for that, be interested to know. I made my own from a bearing and some machined flanges for the air shifter on my dragbike's gearbox, but my shaft rotated at 500 rpm.
