Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 31
Thread: Looking for a rotary joint, no idea what its called :)
  1. #21
    Aug 2007
    Hertfordshire, England
    Quote Originally Posted by Noitoen View Post
    KISS
    instead of lever, pneumatic actuator
    Yes that sort thing will work, needs to be push-pull not just push.
  2. #22
    Dec 2016
    Helsinki, Finland, Europe
  3. #23
    Jun 2007
    Anderson SC
    Well, considering the small size, and low forces.... what about just a oilite bronze bushing, or nylon, or teflon, or..... you get the idea.
  4. #24
    Apr 2017
    Poway CA
    that's what that does. The long drawbar going to the right rotates with the lathe spindle. That is your shaft.
    Ignore the bright cylinder.
    The dark cylinder with a rivet or bolt on top has a bearing with the inner race attached to the shaft.
    The aforementioned rivet is actually a pivot point so the L shaped piece with the big handle can pivot with respect to the shaft.
    That handle assy rotates around the hole at the back of the L shaped piece. This gives mechanical advantage to clamp collets.
    You could mount a cylinder parallel to your shaft and push pull the handle.
    OR you make a u shaped clevis that attaches to the pivot points on the dark cylinder and attach the cylinder in line out to the left to push pull.
  5. #25
    Jan 2010
    You may want to study how Bridgeport style power drawbars are made with an air impact wrench.
  6. #26
    Apr 2017
    Kelowna BC
    Harley used a small thrust bearing that fit on a 3/8 shaft, but it ran in oil. With a spring on the far end to retract it.
    How much stroke do you need ?
  7. #27
    Sep 2011
    Langley, British Columbia
    PTO drives used on tractors are designed to transmit rotary motion and slide in and out to compensate for changes in length
    when cornering or going up and down hills. Sounds like your application is smaller but there are places that make smaller
    splined shafts and hubs. One example...
    http://www.sdp-si.com/catalogs/
    Keith
    __________________________
  8. #28
    Jan 2013
    Flanged bearing mount.
    https://www.mcmaster.com
    Inner bearing bushing fastened to the rotating shaft. Flange attached to whatever you want to do the pulling.
    Ken
  9. #29
    Dec 2004
    East Coast, USA
    Quote Originally Posted by Davek0974 View Post
    I think it's a huge joint that moves around from person to person.
    Work hard play hard
  10. #30
    Aug 2007
    Quote Originally Posted by KMoffett View Post
    Ken
    Yep i think that will work
