Page 1 of 6 123 ... LastLast
Results 1 to 10 of 53
Thread: Hydraulic vise - any good??
    Aug 2007
    Hertfordshire, England
    Default Hydraulic vise - any good??
    Looking at maybe getting a new vise for my mill, the old AbWood one is getting a bit sad now
    Anyone know about hydraulic vises??
    Looking at one of these from my tool supplier...
    https://www.cutwel.co.uk/work-holdin...-built-in-type
    Never bought a new one before, more choice than i thought especially if not rich
    The mill is my CNC converted Bridgeport.
    Any tips appreciated
    That looks pretty nice. But what would you use to move the oil? If you're not really NEEDING something like this I'm thinking that the requirement to come up with a variable but consistent once set oil pressure supply might be an issue. Seems like it's more aimed at production work. But I do agree that it seems like a decent vise for the cost
    Aug 2007
    I'm pretty certain the oils is all internal - it uses a wrench like any other vise.
    My only guess is it works something like a Sykes Hydraulic hub puller where a small screw is used to exert very high force but small distance on the puller.
    There's the big hex sticking out that I assumed was a hydraulic fitting. But it could be the stop block that runs the short movement setup as you're saying. It also looks like it has limited travel range and the back piece needs to be shifted with the aid of the through pin in the base and with the use of three holes.
    Apr 2016
    Spain
    I'm currently looking for a new vise, or a way to improve the one I have. The point is, my current vise has too much fix jaw deflection. The solid fix jaw of this vise is pretty nice.
    Another pretty big advantage, that I'm not sure if this vise has (seems that not), is the pull type (instead of push) screw. I have read that this can improve up to 80% of the jaw deflection.
    Jun 2004
    Quote Originally Posted by Davek0974 View Post
    They are grease filled, not oil, I've rebuilt a few failed units.
    Aug 2007
    Hmm, well i did say it was a guess
    They do have other models and makes but all for my needs, need to choose carefully.
    Jun 2004
    I was referring to the Sykes Pullers, not your guess that vices work the same way, which is likely to be correct ;-)
    Aug 2004
    Sunny So Cal
    Quote Originally Posted by Magicniner View Post
    https://web.archive.org/web/20140618...rclecalc14.exe
    I just noticed you have an executable file name in yer tag line. Is that supposed to be there? Never saw that before. JR
    Do they spell "vise" differently in England, "vice"?
