Page 1 of 10 123 ... LastLast
Results 1 to 10 of 97
Thread: Small mill project (SMP)
    Jan 2008
    Default Small mill project (SMP)
    I got a small used cnc mill a year or 2 ago and have not had a chance to go through it and fix it up. The ways (sliding surfaces) look really good - but most everything else needs a little TLC. (ball nut mounts not parallel to the slides and such)
    The mill is torn down to its individual parts and being gone through. Currently working on the Z axis slide. Again - the sliding surfaces look great - but the mating surfaces are a bit off.
    What to do.. Mount it on the big mill of course!
    Using some ground rod/123 blocks to make sure the ways are parallel and perpendicular to the K&T.
    True up the mounting surfaces... (took off about .002")
    And done..
    Things to do yet on the Z axis column..
    - mill the relief for the ball screw nut further. (go into the more later)
    - mill the mounting holes so they are symetrical. (they are all over the place.)
    - mill some line up edges for mounting to the base. (I am adding a 4 inch riser block so there is more space between the spindle and the table)
    I think that is it for now.
    Jan 2008
    This is it cutting before I took it apart
    Mar 2010
    switzerland
    would you have a picture of the whole machine?
    Jan 2008
    Hmm - That is a good question... I didn't really think about documenting it until I had it tore apart.. Go figure.
    Oh - I have a crappy one...
    Jan 2008
    This is what really set off the 'go through'
    The x axis ball nut block was not mounted parallel to the ways. (poor thing) and the more I dug into it - the more little problems there was. (not unexpected - this was a prototype)
    This should be one solid machine once I am done.
    sam
    Jan 2008
    Found a chunk of cast iron (part of an old grinder..) to make a 4 inch riser. (this is to raise the Z column)
    I needed a piece about 7"X5"X9".
    East Coast, USA
    Where is the SMP? Are you rebuilding/processing both X and Y axis's at the same time symmetrically?
    Work hard play hard
    Jan 2008
    Started on the base (y axis)
    mounted it similar to the vertical column.. Then trued the feet to the ways then cut some reference points..
    Now - flip it and make some measurements and reference points.
    Jan 2008
    4" Riser block kit... slight machining required. ..
    Jan 2008
    The hacking has started...
