Results 1 to 5 of 5
Thread: Massive Steel Router v. Shapeoko
    Dec 2011
    FL
    Default Massive Steel Router v. Shapeoko
    I've wanted a CNC mill for a long time, but they cost a ton, so I have procrastinated. Recently, I saw a This Old Tony video series, in which he used a home-built CNC router to make side plates for a pasta machine. He also made other parts. The material was aluminum. I was impressed that he was able to get so much done with a router.
    I'm thinking it would be neat to have a CNC router. I looked at the X Carve and the Shapeoko. It looks like the Shapeoko is a better machine, and it's not all that expensive.
    Here's what I'm wondering: can I do good work in metal with a Shapeoko? I know it won't replace a mill, but it appears that a router can make a lot of useful items, and presumably it could produce things that could be finished more precisely on a manual mill.
    Tony built a colossal machine with extremely heavy parts, and his router has a table that moves under the spindle. The moving table is 3/4" thick. It's very impressive, but I don't know why he needed all that mass or the complication of a moving table. Other routers weigh a lot less and have stationary tables with spindles that move across them in both directions.
    Do I really need a thousand-pound router to do good work in aluminum, or would a Shapeoko do the job?
    Don't trigger me, bro!
    Quote Originally Posted by stevehgraham View Post
    https://youtu.be/b-yBVOiJ4dY?t=286
    Apr 2002
    Central Iowa
    If you want a toy or hobby machine to play with that's all ok. I have a real CNC 4x4 Saturn 2 router ordered from Fine Line Automation and I ordered the NEMA 34 motor options. They are based in NC USA not Chinese. I am making money with my lasers and this is just an extension.
    https://www.finelineautomation.com/t...hines/new-node
    Retired - Journeyman Refrigeration Pipefitter - Master Electrician - MakerGear M2 3D printer- 20 Watt Ray Fine Galvo fiber laser, LightObject 40 watt co2 Laser Engraver
    Dec 2011
    FL
    What do you expect to have in that thing before you get it running? It appears to be nothing but a frame and gantry.
    I'll post a link to a video of the machine Tony created. I don't understand why the table needs to move or why it has to be 3/4" steel.
    Apr 2002
    Central Iowa
    The gantry and frame are sold without motors or electronics because some people prefer to roll their own. I added on the complete plug and play NEMA 34 motors, wired and controller panel. ESS controller and Mach 3, drivers and all with stand I think around $7300 or so. Some assy required. You end up with a steel frame and gantry, rack and pinion X-Y ball screw on the Z. You buy your own router or spindle. I ended up with a Hitachi 2.25 Hp router motor. The Fine Line Automation is right up with Camaster for build quality and its made in USA.
    Its a 51x51 inch work area. Free shipping via FedEx freight to your terminal.
