Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: In Honor of Sir John...
    Mar 2003
    Default In Honor of Sir John...
    I'm rebuilding my old Wellsaw horizontal bandsaw, and one of the tweaks was to fix the wobbly motor pulley. The shaft of the motor, on close inspection, looked like someone had put a file to it as the motor was turning. Measuring it showed I was right- the shaft was, in spots, nearly 20 thou undersized, as well as slightly tapered, and generally egg shaped.
    I tried sending it off to the UK to the experts at this sort of thing, but the box was returned as "undeliverable". Blighter's likely down at the pub having a beer and some sausages.
    So, I decided I'd do it myself. A quick aluminum collar to protect the bearing surface, and piled on the weld- with my recently-resurrected Miller 200 MIG, too.
    Once it was cool, I used the old sod's trick of a steady on the bearing surface to recut the center-drill on the end of the shaft by single-pointing it, and after that, it's a standard turning exercise.
    And done!
    I still need to recut the keyway, but she's done and precisely on spec. Blighter'd be proud, I think.
    Doc.
    Nice.
    bet you are right......
    On the Oil Coast,USA
    Nice job,I think he would approve.
    A salute to him and to you too. He did some amazing saves on buggered machines and made it look like it was no big deal. It was great that he shared as much as he did - the techniques and the humor.
    Nice job.
    Did you run into any hard spots or pin holes when you were turning it.?
    JL......
    Aug 2004
    Sunny So Cal
    Quote Originally Posted by Doc Nickel View Post
    Doc.
    Nice. Thanks for posting. Good fix. JR
    Mar 2003
    Did you run into any hard spots or pin holes when you were turning it?
    -There's a vague shadow of the weld at the bearing end...
    ... But that's about it. I was pretty careful to wire-brush between 'coats' (and remembering to let the weld "dry", too ) so there weren't any real inclusions or cold shuts.
    And no hard spots. I did do the welding outside, but the breeze was minimal, and it got pretty hot during the process. I tried to keep it well below "red", and didn't quench anything. Just left it to cool for about an hour before I started the machining.
    My only real worry is a HAZ transition at the base of the bearing step, due to the end of the weld and the aluminum collar. I don't think it'll be an issue, I'm sure the shaft is just mild steel anyway, and like I said, I didn't quench anything.
    In any case, it's only about a 3/4HP motor and on a bandsaw. It shouldn't see a lot of abuse.
    Doc.
    South Wales
    I dub thee “sir John jr”, arise to defend the humble bandsaw
    Nice job
    Mark
    Dec 2011
    Once it was cool, I used the old sod's trick of a steady on the bearing surface to recut the center-drill on the end of the shaft by single-pointing it, and after that, it's a standard turning exercise...Doc.
    That looks fantastic. But can you explain in a bit more detail how you go from the blobby welded part to the next image where it's cleanly being machined on the lathe? I missed Sir John's original treatise on the method.
    That's not even worthy of being called a clumsy bastard in fact I think he'd overlook that and actually be proud of you - good duty and thanks for bringing the guy up, one of my all time hero's on this site...
