Results 1 to 10 of 27
Thread: Designing bevel gears
    Default Designing bevel gears
    I have a back burner burner project to which I think bevel gears might suit.
    Up to about 500 Watts needs to be transmitted at right angles with ~3:1 reduction, pinion ~2" dia and crown ~7" dia. Pinion rpm ~2100.
    The question is what materials will make reasonably quiet running gears with no or dry lubrication and decent life?
    Will a combination of some kind of plastic and metal work?
    I have a set of M1 cutters, will M1 gears of reasonable tooth width work?
    Just tell me if I am dreaming, I'm open to suggestions.
    John.
    Sep 2015
    NW Illinois
    You definitely want steel for the pinion. I am not sure how a plastic gear would perform. It is worth a try. I suspect canvas reinforced phenolic for the nonmetallic gear. If you haven't got Ivan Law's book on gears and gear cutting I suggest getting a copy. As far as strength design goes there are probably online calculators available. One way to lower the tooth loading is to increase the pitch diameter of the pinion and gear.
    Given your desire for long life, quiet operation and little or no lubrication I'd say that the best way to design them involves ordering suitable parts from some drive line component maker like Small Parts. Making spur gears is one thing but making smooth running quiet bevel gears would be a whole other level. Tapered teeth and all that you know.... And 500 watts is 2/3 of a HP. So that's not light duty to my way of thinking.
    It would be overkill but if you're considering a 2" crown and 7" pinion then find a small rear axle from some sort of compact car and adapt them to your needs. They would require lube but they would be very quiet.
    But considering that gears that size easily handle many HP I'm thinking that you don't need anything that size.
    My first thought is one brass and one steel, involute.
    My second thought is to dismantle an angle grinder.
    May 2011
    What does Ivan say?
    Maine
    It's been a while since I read Ivan Law's book (Gears and Gear Cutting) but I do remember that he explains how to cut constant-depth bevel gears. They aren't the same tooth profile as commercial bevel gears, but they are a valid form that work. They can be cut using "normal" shop equipment; they don't require specialized gear-cutting machinery.
    If you want to try cutting bevel gears, I highly recommend that book.
    South Wales
    My first thought was worm and wheel to do the grunt then use further gears to get to where your going
    Mark
    Helsinki, Finland, Europe
    Quote Originally Posted by mihit View Post
    Angle grinder gears are available also as spare parts. Small grinder gears are dirt cheap(something like 4usd per set from aliexpress) but probably underrated for the OP's task.
    230mm/9" angle grinder gears could be enough sturdy, first one that I found on google:
    https://www.ptctools.co.uk/spares3.php/sn/SPARE_GA9020
    Sep 2006
    Southwestern Ontario, Canada
    Quote Originally Posted by SGW View Post
    If you are cutting gears on a mill, using gear cutters, then the constant depth method is the only way you can do it. It is a perfectly valid method, the gears run fine as long as you don't try and mesh them with commercially cut gears.
    Sep 2006
    component maker like Small Parts. .
    Are Small Parts back in business?? Amazon bought them out at one time and totally buggered them up.
