Results 1 to 8 of 8
Thread: Need Help Plotting Circuit Board and Schematic Diagram Files
    Mar 2015
    Question Need Help Plotting Circuit Board and Schematic Diagram Files
    Digital Machinist articles sometimes reference electronic circuit diagrams (.sch files) and printed circuit board layouts (.pcb files) that can be downloaded from the website. I have been able to download these files but have not been able to fine a way to plot or print them.
    I have tried loading them into QCad which only resulted in an error message. I have loaded them into Autodesk EAGLE which will only display the text file; not the schematic diagram or circuit board layout.
    I would like to hear from anyone who has succeeded in working with these files.
    Sep 2011
    Langley, British Columbia
    I don't know if this helps or not but it might be worth a try. Perhaps you can open a file in TinyCad and then
    print from there...
    https://sourceforge.net/projects/tinycad/
    Keith
    __________________________
    May 2011
    Do you have a link to a specific article?
    Jan 2008
    Traverse City, MI
    I'm guessing you are referring to the DRO article by Blaine Geddes?
    Editing to add that I did some digging through my files and found we had some problems with the files in this article. The original plan had been to offer the DXF files. However, they kind of blew up in the translation and I was forced to redo most of them. My efforts were to get them into the magazine clearly. In order to do so, I had to tweak the line weights and other things enough that the geometry was fine for making the specific files I needed to pass to our artist, but would probably take some work to use in other ways.
    Because both the author and I had doubts about the usefulness of the DXF files, he supplied the .sch and .pcb files, hoping they would be readable. He had wondered about the readability though, as he uses a variety of old systems in his design. We hoped the files would be helpful, but if you can't read them in EAGLE, then maybe they aren't so much.
    You can contact me at gbulliss(at)villagepress(dot)com and I'll pass along any other files I may have. While the DXF may need some work, it may be the easiest way to get what you need.
    George
    Apr 2010
    Canada
    Free Kicad uses .SCH and .PCB files, they may have been created with it.
    When universal Gerber files are created for the board shop, there is a few Gerber viewers available if you can also get these files
    If trying Kicad, use the previous version not the current 5.5 .
    Max.
    Could be Eagle, which is a popular program for printed wiring board layout together with schematic capture.
    Jan 2008
    Traverse City, MI
    Jack contacted me via email and I've sent along some dxf, pdf, and tif files that, hopefully, should work for him.
    If anyone else would like or need these files, contact me via the email address I provided in post #4 and I'll be happy to send them.
    George
  8. #8
    Mar 2015
    Default Thanks to All for the help
    I just wanted to thank all of you that responded to my request for help. It appears that the original circuit board file was made with Qcad and I have been able to use it to increase the trace widths and pad diameters to a proper level to use for the circuit board. Plus I'm pretty excited about KiCad. It looks like a really capable free package and I was just looking for something to occupy my time now that golfing season is over. I think I'll try doing the board over again from scratch as a project in KiCad.
    Anyway; Thanks to All.
