Results 1 to 10 of 16
Thread: Odd bridgeport m head?
    Nov 2018
    Default Odd bridgeport m head?
    https://flic.kr/p/2bmmQ58
    Anyone know why this bridgeport head has a diiferent casting with 3 exra allen bolts added? There had to be a purpose for them.. And theres no serial number stamped on it.
    https://flic.kr/p/2cEB5wh
    Buffalo NY
    The casting is split to the quill to adjust the pinch of the bore.
    There is felt in the split line, which has been partially painted
    over.
    -Doozer
    East Coast, USA
    It's amazing how bad some of those machines look on the outside; yet they sometimes look like new on the inside but still not very comforting when all you can see is the outside.
    Work hard play hard
    Stevens Point, WI
    over.
    -Doozer
    This ^
    I had a camel back drill press with a split casting. The casting was bottomed out and the quill still flopped around some. She was well used. Hotdog down a hallway.
    East Coast, USA
    This ^
    This ^ sounds like this:
    Work hard play hard
    Jul 2005
    Chester, NH
    The split casting is pretty common on drill presses and such but all the M-heads I've seen do not have a split casting. Maybe this is just a very early version??
    Are you sure it's a Bridgeport and not a clone? It definitely looks like a BP from the photos but... ?
    Apr 2017
    Kelowna BC
    It looked to me like something bolts to it, like a steady bracket between 2 heads on a tracer mill.
    Deep in the Heart of Texas!
    Geez, is that a guy, girl or tweener?
    He said camel back not camel toe.
    Nov 2018
    I looked at some of the machinery museums that had photos of very early bridgeport milling machines. None had heads with split castings. Really strange....
    It's definitely a bport head. The upper housing is a bport. Although the tag with the serial number is missing.
    I looked all over the Internet for m heads. I saw a few that were odd. One had a different lower casting, with the fine feed positioned differently. One had an upper casting with the motor entering through the bottom of the upper housing.
    I removed the paint from the side of the casting. You can clearly see where the casting is split.
    https://flic.kr/p/P1U54i
    Buffalo NY
