Page 5 of 5 FirstFirst ... 345
Results 41 to 48 of 48
Thread: Engine Flywheel Resurfacing
  1. #41
    Mar 2008
    Kent, U.K.
    Yep I had to do that on my bike's plate to keep the clamping pressure.
    Monarch 10EE 1942
  2. #42
    Jan 2014
    Edmonton Alberta
    Especially when Jethro takes out the new clutch brake on the first day because he just can't grasp the concept of why it went out in the first place! LOL
    On the topic of clutches my 1990 Autocar Tandem/Tandem grain truck has a air assist clutch.It has a typical Hyd master on the pedal and slave with a air pot on clutch housing,first I've seen of this style,are they common?
  3. #43
    Jan 2009
    WV
    I did this one on a mill so they can be done that way. Also converted the center for a bearing instead of a pilot bushing.
    This was the before.
  4. #44
    Oct 2005
    British Columbia
    Quote Originally Posted by Tundra Twin Track View Post
    I've heard of them before but have never driven anything with one installed, although I do know that some Macks and Volvos had them in addition to Autocar. All of the Western Stars, Macks, Navistars and Kenworths that I'm more familiar with all had strictly mechanical linkages for the clutch.
    How are they to operate? I'm guessing a little more "clutch leg" friendly.
    Been meaning to ask, did you get enough dry weather in Oct. to be able to justify getting the grain truck out of the barn? Pretty wet/cold Sept. up your way if I recall.
  5. #45
    Jan 2014
    Edmonton Alberta
    It very easy on the leg but if not aired up takes a lot of grunt to pedal down,the master is seeping so got new one to install.The bottom slave & airpot setup is $1200.
    This past Harvest was very Brutal, Dryed a lot of the crop but got a real nice stretch of weather in Oct.All the grain in bins but no fertilizer on,that will have to wait spring.That is the 3rd very tough harvest in a row,taking all the fun out it(I have different words to describe it but would get kicked off Forum lol!)
  6. #46
    Stevens Point, WI
    Quote Originally Posted by Ridgerunner View Post
    How did you turn that? Is it a cnc machine?
    I haven't done a clutch yet but I did surface a plate that I used for a scroll bender deal. Surface finish was plenty good enough for clutch use.
    Aug 2018
    Agree with the low cost of new parts. Wife bought a new jeep grand cherokee, at 10,000. Miles the brake pedal was pulsing bad. Dealer wanted$600 to replace rotors, and said to expect to have it done again at another 10M miles. Went to parts store, bought hi-performance rotors an pads, paid $300, and when she traded at 80,000 never had the problem recur.
  8. #48
    Jan 2009
    WV
    Yes. Very simple. Once X and Y zero are found; Z is then set (depth), then just program a circle with whatever radius and away it goes.
