Results 1 to 10 of 12
Thread: The Spline Adventure Continues.
    Sep 2004
    Default The Spline Adventure Continues.
    thanx Yes I also thought In volute , I measured across the Mating gear, It was 1.025 Diameter, at least thats in side the gear at the Largest Diameter of the Spline. It also is a 15 Tooth and has from what I can deduct a 30 degree angles. Now I did look in the Internet for spline tools (expensive) and thought maybe one could be milled from ) 0-1 with a Tapered end mill the right diameter and angle (angle would be probably just relief) Like mill front of tool for Clearance then with tool In vice centralized (Indicated 0 0 ) a Plunge cut on each side to the correct Dimensions, This is some Information Gleaned from a John Stevenson Article. (He was a Good Guy!! ) this is all I have so far, If I had any cad skills I could maybe figure it out better. I was hoping a More Intelligent fella could maybe come up with some sketch of the Tool Needed, Then I could make one from silver steel or 0-1 and try to heat treat it afterwards. I have a oxy propane torch wich works quite well. Thank yoo guys Im in a Lurch with this.
    Jul 2017
    Buffalo NY USA
    I would be very surprised if it isnt one of the types mentioned in machinerys handbook. Thats the irst place i would look to get a cutter profile.
    Jun 2012
    San Diego, Ca *** Please let us know where you are from too.
    Why start another thread when your original thread hasn't even left the front page yet. Just curious.
    John Titor, when are you.
    Sep 2004
    Mike when the second Post came it was a bit different in Topic regarding making possibly a Home Shop Tool to do this Job Correctly. Its all a learning experience for me, a relatively uneducated Fellow in the world of Splines and gears and How to make tooling for them. i find it Interesting as heck. i was hoping a more Knowledgable Fellow would shed some Light on the Tool parameters so I could possibly make one.
    Jul 2017
    Buffalo NY USA
    having the original parts available is a huge advantage. I would grab a piece of high speed steel and start grinding it to fit the existing splines, regardless of what type they may be. Of course its a good idea to try and figure it out through reference books just in case. I seem to recall that your spline count divides evenly into 360, so that is another huge advantage.
    Apr 2017
    Kelowna BC
    Like I said, I made one before,
    Hand ground my own single point cutter.
    Used 7075 aluminum shaft for it tying to save weight, and accelerate quicker.. I think was the goal..
    Jan 2014
    Edmonton Alberta
    If you require that exact spline of the Arctic Cat jackshaft on the 1" shaft they are pretty cheap to buy from salvage dealers.
    Sep 2011
    Langley, British Columbia
    Quote Originally Posted by Mike Amick View Post
    Yeah, made absolutely no sense to me. Sounded like you were starting in the middle of something. The
    internet is a big place--we can't always guess what you're thinking...
    Keith
    __________________________
    Helsinki, Finland, Europe
    This is the only way to go in a home shop unless you have fancy tool grinder setups and measuring equipment.
    No need to worry about what standard it is if you are never able to make the cutter based on print
    Sep 2004
    Thanx Guys? My Original Post Arctic Cat
    Thundercat Spline on Jack Shaft. Does any one know anything regarding these? Are they Involute Spline like a 30 degree stub .I dont know much about Splines. I thought first it was a straight 30 degree type but..almost looks a bit .Anyhow any Info would be good. Thanx Guys
    My second Post was Inquiring as to the Proper Nomenclature to develop a suitable Cutting Tool in My Shop. I thought I made that Clear enough ?? Apparently Not. I apologize Guys for my communication Problem. If I Had a cad program I could project a Diagram on screen and see what size dia cutter would work. Anyhow thanx appreciate youre Time Mike
