Results 1 to 6 of 6
Thread: Wiper for Lincoln AC 225-s
    Nov 2012
    Default Wiper for Lincoln AC 225-s
    I have a older Lincoln stick welder. It quit
    working and tore it apart and found the contacts
    pitted and rough. Cleaned everything up and
    tested before putting it back together.
    The wiper on the selector knob shows only about
    1/2 the width of what is should be.
    I know parts are available but for the life of me I
    can not find a part or place to order just the wiper.
    Thanks for any help!!
    olf20 / Bob
    Aug 2018
    Loveland,CO
    You might check with Forney welders in Ft. Collins CO, for parts that may work
    Dec 2008
    The Four Flags City
    Find the part here,
    https://parts.lincolnelectric.com/In...1/products/all
    Then go to your local welding supply and they should be able to get it for you.
    Nov 2012
    Thanks guys! Could not get link to work.
    olf20 / Bob
    Oct 2005
    British Columbia
    Not sure what happened with the BigMike's link but it's dead for me as well.
    Try the one below, it will take you to all of the various AC-225 models, and there are a number of them so you will have to determine exactly which one you have.
    https://parts.lincolnelectric.com/In...MjEzNDA5MzQ5fQ
    Dec 2008
    The Four Flags City
    Now I remember customer service at Lincoln saying they were having issues and they had to look up part by prints.
    When you look it up you will need the code number from the data tag to find the correct parts list.
