Results 1 to 3 of 3
Thread: Punch grinding machine
    May 2015
    Somerset UK
    Default Punch grinding machine
    What is a punch grinding machine? I noticed this one on ebay just now https://www.ebay.co.uk/itm/0-008mm-P....c100008.m2219
    Apr 2017
    Kelowna BC
    Grinding punches to sharpen them, is very common in tool and die maintenance work..
    Sep 2015
    NW Illinois
    That device is used to OD grind punches to a specific diameter. The shank of the punch rests on the steel rolls. A pressure roll holds it in place. Turning the crank rotates the punch. It is usually used on a surface grinder and held by the magnetic chuck.
