Results 1 to 10 of 20
Thread: Thermite Welding
    Jan 2002
    Huntsville Ala
    Default Thermite Welding
    From discussions in the past, others seem to find the thermite process as fascinating as I do. Here's about a 25 minute video showing welding train rails. Appears to be some east european country.
    https://www.youtube.com/watch?v=rNjosF789X4
    I've seen rail welding first hand, but not filling large gaps (look to be an inch or so) such as in this video.
    Jun 2004
    N.J.
    Quote Originally Posted by lynnl View Post
    A similar process is done by Conrail.
    Used to work right by the UP tracks, saw them do it once or twice. Smoky and smelly, but works well.
    (was tempted to ask if you had any proof he ever welded anything, vs just making long incomprehensible posts on PM....)
    Jan 2009
    WV
    When I was in Western Canada I was talking to a railroad guy and he said that was the process they used. What fascinated me was he said there were no joints in their tracks for expansion, which I could not understand. Of course, being Canada, maybe he had a couple of joints before talking to me.
    Nov 2008
    SF East Bay.
    Quote Originally Posted by Ridgerunner View Post
    I'm probably wrong, but I suspect that by "no" he may have meant very few. Our local light rail boasts of "seamless" tracks that have seams every once in a while. A few thousand feet? Something like that.
    Joints in the rail rarely, yes. Also, with many curves in the track, some of the expansion can be taken up by shifting. Long straight runs would need expansion provisions.
    With 1000m of track, and 6 millionths per unit expansion per deg C, every degree is then 6000 um, and 80C change is then almost half a metre.
    Old time track was in 10m or so sections, IIRC, so then there would be about 100 joints per 1000m, and each joint would have to take up 5mm or so. Perfectly possible. Of course, the force needed th shift the joint would need to be less than the force needed to shift the track position, and those rail joints were normally made up tight.
    Aug 2007
    Leics UK
    You can think of thermite welding as actually a small scale, self fuelling, casting process.
    Dave
    Jul 2007
    West Michigan
    I've wondered the same thing. He is currently banned from PM.
    Jul 2007
    West Michigan
    We were coming through New Mexico a couple of years ago and saw a train hauling an odd bunch of cars. Turned out that it was railroad rails. They looked to be at least a quarter mile long but probably much longer. They were on several cars but in continuous rails. Interesting. I wonder what the process is for making such long steel.
    I've seen those when the UP replaced track. I wondered about them going around curves.... you'd think there was a lot of cold-working, but likely they are never stressed over the elastic limit. The railroad does employ competent mechanical engineers....
