We had the same issue in our house. There was a 4’ high by 12’ long 1/4” think mirror mounted to the living room wall above the fireplace. The bottom was resting in a channel, the only other attachments were the 4-6” round blobs of black mastic gluing it to the wallboard. It was successfully removed in one piece by using a series of tapered wood shims along the top edge. They were incrementally and gently(!) forced between the wall and glass. Keeping the pressure even along the top edge allowed the glue to slowly release without breaking the mirror. Some of the adhesive released from the mirror, some from the wall and some tore the paper from the wallboard.
Wear safety gear (goggles, gloves, etc.). While ours was successfully removed, I expected it to shatter or fall unexpectedly. You will need at least one assistant since it will be fairly heavy (>100lbs.) and big.
Tom
Be careful what you wish for, you might just get it!
