Turning inherently creates a grooed finish, that's just how a lathe cuts. The tool shape can improve that, but there is some of that effect regardless of shape. Grinding, lapping, etc are usually needed for items such as piston rods that must slide.
Your speed is a little high, but being high does not bog the machine, exceeding the machine capability does. Capability is affected by motor power, drive type (belt or geared-head), the grind of the tool (flat topped or high rake) and so forth, including the type of material (which you do not know). Speed of the cut, in both feed and RPM, obviously afect the power needed.
Can you tell if the "bogging" is due to belt slip?
What shape is the tool? Does the top of it slope, or does the holder produce a sloping top?
A tool with a definite slope down from left (cutting edge) to right will cut easier, and require less power.
Some materials are just harder to cut.
