Results 1 to 10 of 29
Thread: More help with ID from you guys please
    Jan 2017
    Central Texas
    Default More help with ID from you guys please
    This is on a 1/4" rod about 17" long (square cut on one end, rounded on the other). Was in the old 30's - early 50's machinist chest my girl got me for Christmas. Any ideas on what it is?
    Jan 2017
    Central Texas
    Helsinki, Finland, Europe
    Some sort of crude shaft coupling?
    Apr 2017
    Kelowna BC
    I was thinking, it either hold a clear chip shield or a magnifier.
    Jan 2017
    Central Texas
    I Googled the number on the side, but didn't get any results.
    Mar 2017
    central MA
    Put a couple of blades under those screw heads and you have a draw knife of sorts to deburr sheet metal, cleaning both sides with one swipe.
    Jan 2006
    Suffolk, England
    ^^ -sort of similar, but I think it's a very old version of a copper pipe cutter.
    Couple of rotary blades in there, and just spin it around the pipe to slice it off.
    Apr 2005
    Louisville Ky
    Maybe some sort of indicator holder, there is some reason for the two holes. Have you checked to see if the rod is one piece, the cardboard could be hiding a split.
    Jim
    Jan 2011
    Cinti,Oh
    Surprised no one recognizes it.
    nearly positive it's nothing more than a grounding clamp....holes are for wires.
    I don't think its a grounding clamp - there's no means of tightening the ground wires and the clamps also insulated from the rod,
    it "could" be used as a wire anchor for long rods and to give them stability or something - still don't know why it's insulated from the rod,,,
    it's interesting
