Results 1 to 10 of 13
Thread: Carbide insert securing screws
    May 2015
    Somerset UK
    Default Carbide insert securing screws
    I recently bought a Stellram lathe tool on ebay which is in good condition, but could do with a new insert securing screw. It uses a DCMT 11 insert and is an SDJCR 2020K11. This code is definitely metric, but the screw appears to have a finer thread pitch than standard. Stellram is part of Kennametal and looking up the equivalent tool which also incorporates a shim, gives a screw with a T15 socket and a part number of MS 1156. No information on the thread is given.
    I will have to wait until Saturday to check the screw properly, as my thread gauges are at the museum. I would guess at 3.5mm, maybe metric fine.
    Any info would be appreciated.
    Woodinville, WA
    Jul 2006
    Germany
    I'd recommend that you buy original screws, steel is very high grade.
    On the Oil Coast,USA
    x's2, I've bought hardware from this vendor,really good stuff and fair prices.I bought a pack of spares for every size I have in the shop just incase.They have come in handy several times already.
    Aug 2016
    Appalachian Ohio
    WOW... while some of my tools probably belong in a museum I've never kept them there.
    Aug 2004
    Sunny So Cal
    Nice piece of info. I only buy used holders and with the screw and or buffer plates.
    I have never tried to measure such a fine thread. I cant measure the threads of a tiny shaft in an even smaller watch. Hard to measure that pitch.
    Measuring fine pitches would be a class I would take, JR
    Woodinville, WA
    I also have bought many packets of tool holder screws from this seller. Good guy.
    Central Ohio
    I have also made that once, trouble was that was not what it was supposed to look like.
    mark costello-Low speed steel
    Mar 2015
    Optical comparator?
    Helsinki, Finland, Europe
    External threads are easy enough to measure if you have the correct pitch gauge and the thread is enough long but internal threads are lot more tricky.
