Results 1 to 10 of 34
Thread: Acceptable spindle play, Logan 825 10 lathe
    Jun 2018
    Tucson, AZ.
    Default Acceptable spindle play, Logan 825 10 lathe
    I’m finding it almost impossible to part off with my Logan 825 10” lathe. The work seems to climb up on the tool. I set up a dial indicator on the chuck and found it will lift by .005” when the spindle is static, when I’m trying to part off with a normal top pressure the spindle lifts by .008” I’m just wondering if I need to replace the spindle bearings?
    I removed the spindle and cleaned and regreased both spindle bearings about a year ago. The grease was dried out then and not doing any lubricating.
    Has anyone found the bearing numbers for this lathe? So I can get them locally.
    Jun 2009
    san jose, ca. usa
    the bearings are still available from logan actuator company. you must tighten the spindle nut very tight. it's on the inside of the head stock. I used a punch and hammer.
    http://store.lathe.com/baandoibe.html
    Oct 2014
    I think they are special, pre-loaded, or assembled with precise parts to have about 0 play. I don't know though if they are an odd size though, you may be able to get them locally or you need to contact Logan Actuator.
    Jun 2009
    san jose, ca. usa
    Quote Originally Posted by wdtom44 View Post
    they are, special that is. and I think they are special made for logan.
    Jun 2018
    Tucson, AZ.
    I know I can get them from Logan. I’m just wondering if there is another source. I’m retired and Logan’s price is a bit high for me! And I’m not sure this will fix my issues.
    There is maybe .002 thousands end play on the spindle, bearings feel smooth, but this lathe is 74 yrs old.
    Jun 2009
    san jose, ca. usa
    Quote Originally Posted by RockingJ View Post
    no other source that I could find. try the adjustment. my lathe is 73 and has no play.
    8 thou in the spindle bearing is just about IMPOSSIBLE. It would have had to have been lubricated with diamond dust for that to ever occur. Almost certainly that issue is elsewhere.
    First, make CERTAIN that the problem really is the spindle moving, and not the headstock or something else. Put the indicator base on the HEADSTOCK and repeat your check, measuring to the actual SPINDLE. That way you limit any movement to actual movement of the spindle in the headstock.
    if you get the same type results, then we'll talk about more things.....
    if your spindle bearing has ever been replaced, and I would almost bet that it has, then you could have a problem, but not 8thou, or even 5 thou worth of problem. My guess is that you are measuring the sum of other issues common to older machinery, and which are fixable if found.
    Stuff that can cause that movement between tool and spindle includes the following:
    headstock not tight down on bed. possibly resting on a piece of swarf and able to tilt.
    Sloppy adjustment of gibs in crosslide and/or compound
    Just plain wear. Wear in some places and in a certain manner, can let parts "rock" and cause issues. So can a piece of swarf under the compound swivel
    A toolpost that is too flexible. The "lantern" post can do that, especially if the tool and/or holder is stuck out too far.
    Sticking the compound and/or cutting tool too far out. Keep the front of the compound over the dovetail way it moves on.
    Having the work sticking too far out
    Not having the chuck screwed down to seat properly on the spindle, which can let it move.
    This is a partial list, there are more things..... And, there is always a little bit of flex in the lathe itself. Might amount to a thou or so with a heavy force. But the Logan is a very nice usable lathe of its size, I have a model 200, which is very much like your machine, just an earlier model, and I like it. There is no way stuff should move to the degree you suggest.
    RockingJ, perhaps to quiet the doubters you might describe the setup used to test for the play you found? I just assumed that you would be securing the dial gauges to the bed and lifting, pushing or pulling to get those readings.
    OREGON
    Looking back to the original post, He did say he had it apart to clean and lube the bearings. I'll becha a beer a readjustment to the bearings will fix this. If it's that far out, it's probably been that way since he put it together after the lube job.
    Jun 2018
    Tucson, AZ.
    I set up a dial indicator on the top of the chuck and the mag base was on the top of the gear cover. First I put a lever under the chuck and lifted the chuck with out a lot of pressure just enough to see if there was play. This method showed me .005”. Then I set up with a carbide insert parting tool in my quick change tool post with the least stick out I can get with that tool holder. I still had the indicator set up on the top of the chuck. I ran the lathe at the slowest speed back gear and as soon as I put normal tool pressure on the part the chuck rose up .008. This rules out cross feed problems, compound problems.
    The parting blade was exactly on center. I have 4 different chucks and I have this issue with all of them.
    I haven’t checked if I get the same issue on the just the spindle, I will do that tomorrow.
    I know my lathe is old and has issues but nothing major. I am fairly competent as a machinist and have been running this lathe for about 10 yrs in a hobby shop setting. I used it in my fabrication shop occasionally but not often. This parting issue is not a new issue, I’ve always had the problem but I’m finally getting around to addressing it.
