Results 1 to 10 of 26
Thread: Realigning a rebuild bandsaws' wheels?
    Mar 2003
    Default Realigning a rebuild bandsaws' wheels?
    I'm closing in on the rebuild of my Wellsaw horizontal bandsaw. Here's a "before"...
    And here's a current pic:
    I've gotten it far enough it's time to try installing a blade and aligning everything. I'm a little stuck on that point, though- the manual is of little help, as it assumes the alignment is close, and just needs fine-tuning.
    But I had this thing apart down to the last screw, and both wheels have options for tilting the wheels in both axis. So I need to get the wheels coplanar- if that's the correct term - in both tilt and skew.
    I'd originally planned on using a couple of chunks of angle iron or angle aluminum as a straightedge, but unfortunately, parts of the support frame are in the way:
    So you can't really even eyeball down the faces. So any other ideas? Clamp a couple carpenter squares to each one and eyeball down the 90 degree face?
    Doc.
    Jan 2019
    Rochester, NY
    Place risers or blocks of equal dimension on the pulley sides as sighting surfaces? Andy
    Andrew R Stewart
    You Think too Much
    Nov 2008
    SF East Bay.
    First I'd spin the wheels to determine whether the outer rim (like in that last picture) is a good reference edge. I'm assuming that it is.
    Then I'd put a 2x3 bar across the edge to establish a surface that is parallel to the rim but 2 or 3 inches higher. I'd do that for both wheels.
    Then I'd put a long carpenter level (or other straight edge) across the span. It should go all the way to the outside edge of your wheels. That would let you know which is higher, whether they are tilted, etc.
    Dan
    As mentioned use spacers of some sort to allow a long straight edge to extend over to the idler wheel. Keep in mind that the tilt setup will mess with your head but if you take the far and near distances from straight edge to rims of the idler and find the average that should be the same as the height of the spacers you used to allow the straight edge to clear the frame/housing. If not space the driven wheel in or out on the axle to make it match.
    And hey, nice job on the re-build. Looks spiffy and ready to rock!
    Mar 2003
    After checking several YouTube videos, yeah, it seems a reliable straightedge that can span both wheels is virtually a requirement.
    I think what I'll do on Monday is go buy a chunk of 1/4" x 2" or 3" bar long enough to span the wheels, and just mill some notches where it'd interfere with the frame. I'll have to double-check afterward to make sure the milling didn't release some tension and cause it to warp or twist, but I think that'll be a lot easier than having to handle extra spacers or blocks. Especially since this is all overhead.
    If anyone's interested in the nitty-gritty on the rebuild, I have it up in my Projects Pages, including fixing this terrible prior repair, from this:
    Which looked more like this when ground down:
    To this:
    You'll also find a more complete write up- albeit not as tongue-in-cheek- of my motor shaft repair that I posted here last summer.
    Doc.
    Jul 2012
    London, Ontario
    can you measure from the rim of the wheel back to the head at four points around the rim to get the rough alignment. That would get each wheel square to the frame and roughly in line with each other.
    Peralta, New Mexico USA
    I think I'd find a chunk of 3/16 or 1/4 stock long enough to span the wheels and tack some to the edge to reach into each wheel. So maybe 10' of stock to start? You might be able to just clamp things together but it's likely as easy to tack weld it for the job.
    This is what parallels are for.... that will help in one direction.
    In the other, it gets more complicated, unless you have a rigid frame with two crosspieces (known to be parallel) that can be laid on the wheels and used to check the direction perpendicular to the cut.
    I do not think it could be "sighted" very accurately from one to the other, but maybe.with three parallels, so that with two on one wheel and one o the other, the two would establish a line of sight. Both this and the previous assume (possibly wrongly) that the wheel surfaces are well aligned vs the blade.
    Another way more directly connected to the action of the wheels (assuming they are NOT crowned), would be to clamp parallels or similar to the actual blade surface of the wheel, so they stand up parallel to the axle. Then turn both wheels to bring the parallels to the same position, right where the blade starts the contact the wheel. The parallels should be fairly obviously actually parallel or at different angles, so they can be adjusted to be parallel, taking care of the most difficult direction.
    Mar 2003
    Quote Originally Posted by bandsawguy View Post
    -That's just it, the frame is a weldment, and has had a rough life. I can't really assume the ends of the frame itself are anything like coplanar.
    -Tack weld to balanced cast-iron wheels, eh? I think we'll save that one for a "last resort" attempt.
    [...]unless you have a rigid frame with two crosspieces (known to be parallel) [...]
    -Again, the frame's a welded assembly, and the whole saw has been treated badly over the years (best guess is this thing's pushing 50 years old.) I have no common datum point to measure anything from- I can measure from the wheel to it's own end of the frame, but I have no way of telling if that reference is in any kind of alignment with the other end of the frame. Well, apart from the Mk I Mod. 0 eyeball, but that's been known to fall out of calibration on occasion.
    Doc.
    On the Oil Coast,USA
    Doc,from having done it a few times on a couple different model Wellsaws it's pretty simple.Just make sure the drive wheel is parallel to the frame casting,that;s pretty much it.
