Results 1 to 10 of 38
Thread: What are the common triangles, OT, laying floors ??
    Dec 2018
    Default What are the common triangles, OT, laying floors ??
    I'm in the process of laying new floors in the house. What are the common size right triangles other than the 3-4-5?
    When you do the a-square + b-square = hypotenuse math, you most always get a odd number with long decimal answers.
    What are the common answer 45-45-90 triangles that can easily be measured on a fractional tape rule?
    any other triangles easy to read on tape rule?
    Mar 2002
    Kirkland, Washington
    For the 3-4-5 think in units. That is it can be inches, feet, yards ,6 inch=1 unit. You do not have to do the whole wall of a room, just most of the length that works out with your units.
    So the sides can be 3-4-5 or 6-8-10 or 30-40-50 in what ever unit you choose. To put it another way (3x5=15) (4x5=20) (5x5=25) if your unit were 5.
    for 45-45-90 triangle the two 45 legs are the same number/length and the long side is the length of a 45 leg time 1.414 (the square root of 2).
    Jan 2009
    WV
    Any multiples of the 3-4-5. 6-8-10, 9-12-15, etc.
    Jan 2002
    Huntsville Ala
    I first learned it in high school vocational ag class as 6-8-10. But any three numbers of that same ratio yields the same, though the larger numbers offer greater potential precision, . (i.e. measuring precision, not trigonometric precision.)
    Sep 2006
    Southwestern Ontario, Canada
    For a 45-45-90 degree triangle...
    multiply the short legs by 1.4142 to get the length of the long leg
    Multiply the long leg by .707 to get the length of the short legs.
    Saskatoon, Saskatchewan
    That's where a metric tape measure shines. If you have one marked with both imperial and metric it's also a converter from one to the other.
    Jan 2002
    Huntsville Ala
    As to the "odd number" issue, that hardly matters nowadays; everybody (except me) has a smartphone grafted to their body as an extra appendage, with a trig app always ready.
    LA, CA, USA
    Triplets such as 3,4,5 are termed Pythagorean triples. You can learn more about the subject at this Wikipedia article...
    https://en.wikipedia.org/wiki/Pythagorean_triple
    Copied from that article, here are some of the possible Pythagorean triples...
    (3, 4, 5) (5, 12, 13) (8, 15, 17) (7, 24, 25)
    (20, 21, 29) (12, 35, 37) (9, 40, 41) (28, 45, 53)
    (11, 60, 61) (16, 63, 65) (33, 56, 65) (48, 55, 73)
    (13, 84, 85) (36, 77, 85) (39, 80, 89) (65, 72, 97)
    (20, 99, 101) (60, 91, 109) (15, 112, 113) (44, 117, 125)
    (88, 105, 137) (17, 144, 145) (24, 143, 145) (51, 140, 149)
    (85, 132, 157) (119, 120, 169) (52, 165, 173) (19, 180, 181)
    (57, 176, 185) (104, 153, 185) (95, 168, 193) (28, 195, 197)
    (84, 187, 205) (133, 156, 205) (21, 220, 221) (140, 171, 221)
    (60, 221, 229) (105, 208, 233) (120, 209, 241) (32, 255, 257)
    (23, 264, 265) (96, 247, 265) (69, 260, 269) (115, 252, 277)
    (160, 231, 281) (161, 240, 289) (68, 285, 293)
    Regards, Marv
    Dec 2018
    Ah yes, the pythagorean triple is what Im looking for.
    All those are easy numbers to see on a common tape rule. But, those whole numbers end up with triangles tall and skinny.
    Is there a way to see the triples in 1/2" increments? maybe that will yield triangle sizes useful in house rooms.
    Woodinville, WA
    Tail and skinny? not sure about that...
    As stated above, units don't matter. Multiples of 3,4,5 "half inches" work fine also. To reduce confusion mark out on your selected set on the tape measure tape (or a "story pole") with a felt marker. Any size you want. Done
