Nice work, could you tell everyone what tools you used to get the turning and boring done?
Agree with RichR, first picture looks like a 6 jaw. However the third is a 4 jaw. Anyway, a nice job and the finish looks very nice.
OK - tools I used were just a simple flat top TPG 332 insert on the OD, and a SECO WNMG 432 insert on the boring bar. I don't know the grades. OD was done at moderate speed, and the ID was done real slow in the back gears and with a 0.022 feed.
pics of the car when i picked it up - has not run in 20 years, and still has a 1967 inspection sticker in the windsheild
Nice job on a grand ol' car and it looks to be in great shape! Gotta love those suicide doors. Thanks for posting.
(ps: With my luck the Loctite would have grabbed with the sleeve half way in.)
That was a good fix. I had to do the same thing to my Delta drill press. Bore and sleeve it for the quill. This brings back memories.
JL...................
Back in the 1990's I was employed in a shop that serviced heavy equipment such as semi trucks and Caterpillars. It was routine to use the green Loctite sleeve locker on replacement sleeves for the pins. Said pins were in the range of 3" dia 4140 and took static loads up to 50 tons. Dunno what the shock loading was. In fact, Caterpillar included the Locktite in their overhaul kits, with a chart specifying the clearances. So yes, I'd say its OK to use the green Locktite and follow the manufacturers instructions.
