Results 1 to 6 of 6
Thread: Small-shop coolant options...
    Aug 2007
    Hertfordshire, England
    Default Small-shop coolant options...
    Hi all,
    I have a converted Bridgeport mill, i do a fair bit of aluminium on it but only every other week or two so its intermittent use.
    I currently run a FogBuster MQL system with a vegetable based oil (Aerolube) but due to my intermittent nature of use, the mill is now getting covered in a thick sticky gunk when the oil dries out. This gunk is a bugger to shift, it needs hot soapy water which is clearly no good for a mill table etc.
    I can't run flood coolant as the mill is fully open and with the rate of use it would be rancid very quickly.
    Is there ANY other option that i can use for CNC milling of aluminium with HSS tooling and intermittent use???
    Obviously it must be lung-safe although there is very little over-spray when in use.
    Thanks
    Dave
    Feb 2019
    My previous shop had a Datron CNC Router that used alcohol for a misting system. We of course had to plum a vent line to the outside but it worked very well. Nice dry chips when cleaning but lots of fine aluminum dust also.
    Sent from my iPhone using Tapatalk Pro
    Aug 2007
    I think i have a fluid now - UNIST 2210AL is veggie based and so far seems excellent, says it does not dry to a varnish and i have left a film on various parts to test this. No smell at all, it wets the metal better than the other fluid too.
    Jun 2007
    Anderson SC
    Quote Originally Posted by Davek0974 View Post
    That is the exact oil I used on my MQL system. I had no complaints at all. I still have the system from my previous bridgeport cnc but have not reused it yet. I went with flood this time and a synthetic that does does not go bad. The flood is a lot more messy, the MQL is superior for aluminum. I did NOT like the MQL for steel, the heat generated made it smoke and stink.
    Aug 2007
    Good to hear, thanks.
    This fluid is alu only, i asked and was advised NOT to use it on ferrous, stainless or brass at all. With the small amount of ferrous i cut i don't think running dry will matter and i always run brass dry.
    I used to have flood on it but the mess on an open mill is not good so i ditched it
    Jun 2007
    Anderson SC
    Just realized that I told a little white lie. The oil I used was 2210EP Pretty much all the same anyways.
