Results 1 to 10 of 23
Thread: Some test shots with Andonstar ADSM 302 HDMI digital microscope
    Helsinki, Finland, Europe
    Default Some test shots with Andonstar ADSM 302 HDMI digital microscope
    Some other notes:
    +Good focusing range from approx 40mm to Infinity!
    +Plenty of working distance available if you want to do soldering or something like that.
    -Bit too laggy to do something like soldering under the microscope, don't expect anything with 30hz screen update rate to be better than this tough.
    +Build-in display is better than than I expected, really good viewing angles and resolution is "good enough" (not specified but I'd WAG 480P to 720P)
    West Sussex UK
    Excellent image quality. What's the magnification? Variable?. Do you have an HDMI socket on a laptop??
    Quote Originally Posted by Alan Smith View Post
    Fixed magnification so it depends on distance. (plus 4x digital magnification)
    40mm focusing range gives you about 4mm wide area to view. 2X digital zoom looks reasonably good on 27" full HD display so that gives 600:2 or 300X magnification if you want to calculate it like that.
    Tested with separate display with HDMI input, I'm not aware of any laptops that would accept HDMI input.
    Pictures shown are saved to memory card (micro-sd) and transferred to computer.
    Haven't tested the USB functionality but from what I have read its lot more limited.
    This is designed with HDMI and sd card in mind, not USB use. (good thing mostly as video frame rate and lag tend to be lot worse than HDMI)
    Deep in the Heart of Texas!
    No pictures on that link. Just black areas.
    Jun 2007
    Calgary, AB
    Worked for me.
    Do you think this would work well enough to mount over the spindle to see when turning really small parts? I see on Amazon they start at $225CAD, which is a little much to experiment with.
    Jan 2013
    Michigan
    Same here and that is typical imgur. Their priority is to feed you advertising, not serve images. And yet people still insist on using them. They are just another photophuggit.
    Does that sometimes. You might get more lucky with link to public gallery:
    https://imgur.com/gallery/qOlWvB9
    Or invidual pics:
    https://i.imgur.com/ZLTcEky.jpg
    https://i.imgur.com/A7xpLk2.jpg
    https://i.imgur.com/Hze5rB6.jpg
    https://i.imgur.com/U9hPBwn.jpg
    https://i.imgur.com/oFVbTGv.jpg
    https://i.imgur.com/HKnaXqz.jpg
    Quote Originally Posted by Dragons_fire View Post
    Worked for me.
    I'll have to rig up something and try it out.
    Preliminary guess is that it would work, slight lag doesn't feel so bad if you are feeding from handwheels vs. using handheld soldering iron or such.
    May 2015
    Somerset UK
    My Lenovo ideapad 310 laptop has an HDMI port, but I don't know if it works with input as well as output.
