Results 1 to 10 of 27
Thread: Ok, go ahead and have a laugh at my expense.
    Sep 2006
    Southwestern Ontario, Canada
    Default Ok, go ahead and have a laugh at my expense.
    I was turning a part today, basically a ring, 1.4" OD and 1.320" ID. X .5" long.
    So after turning the OD I started boring the ID BUT I accidentally used the OD diameter instead of the ID dim. So anyone want to guess how long it took me to realize that the OD and ID can't be the same Diameter.
    Jan 2002
    Huntsville Ala
    When it disappeared! Hey, where did my part go...?
    that's when you hand the foreman a bag of chips and say "here's your part"
    Stevens Point, WI
    When it started making that crumpling tin can sound?
    Dec 2008
    Kendal, On
    That's truly losing a part in the chip pan.
    I've turned a 3 and a half thou walled part before that I thought was gonna end up like that.
    Sep 2004
    Oregon Coast
    So, how many rings did you turn before you discovered your mistake ?
    Mel Larsen
    Nov 2008
    SF East Bay.
    Well done Lugnut. My claim to fame was to add an O-ring with 1.25 ID on a flashlight body that was 1.35 ID. I did the math. 1.35 is bigger so I should have had plenty of room My math said that I should have had .05 clearance on each side!
    Nov 2011
    Everything is transparent if you make it thin enough.
    Thanks for the laugh. Everyone needs a good laugh now and then.
    Dec 2018
    Can you post a picture of one?
    We just love pictures !!
    Jan 2002
    Huntsville Ala
    He did. There just wasn't much to see.
