Results 1 to 10 of 20
Thread: making Er16 collet chuck
    Default making Er16 collet chuck
    i needed an er16 collet chuck for my stepper motor.
    purchased two from ebay: "er16 collet chuck motor extension"
    i've had much luck with chinese tools, but this time... it was a terrible experience.
    the specs said if i purchased 8mm ID for motor shaft, I would receive 7.98mm shaft so i could induction heat it, then put it on the shaft
    however, i recieved 8.1mm oversized hole, so i couldn't use it... too much runout.
    took over a month for it to arrive, wasn't going to wait again.
    based on google and forums er collet chucks have 8 degree internal taper angle
    my compound was not gonna have the accuracy required,
    so i used a bevel protractor to get the precision within 0.1 degrees, which for ER collets is enough
    even greater precision could be set, if i purchased electronic bevel protractor, but it would cost me over $600 for quality one.
    i just went with vernier one, which wasn't too bad.
    below is the link to the making vid of this collet holder
    feel free to comment
    https://youtu.be/bQxgMjGpD48
    I haven't watched the vid yet, but you can set the 8 degree to your level of measurement by using one of the collets themselves, assuming they're good ones. Anyway, if you chuck an appropriate piece of stock in the chuck to turn down to a snug fit on your chosen collet, you can then mount the collet on the stub arbor. With an indicator set on the compound, at lathe center height, adjust the compound so it track the collet without indicator movement. I make ER-32 collet chucks and use a sine bar to set the compound and consider it good enough when I get a tenth or less deviation moving the compound. Using the collet itself means you're depending on it to be correct and you've got much less travel to watch for variation but it should be good enough.
    Jan 2014
    In the desert
    Nice video. Why do you need an ER collet chuck on a stepper motor?
    just for a simple cnc machine
    Quote Originally Posted by TGTool View Post
    hm, i've heard you could set the agle correctly without the collet.
    you need to have DRO though.
    just indicate the inside taper of the er collet chuck, and use trig. to figure out the appropriate Z and X amount.
    very simple indeed. need calculator though
    Helsinki, Finland, Europe
    Quote Originally Posted by dovidu View Post
    Or use small sine bar to set the reference angle, check with test indicator. (edit: did I read anything what was already written?)
    Or two dial indicators mounted temporarily to lathe instead of DRO. Better if one of them is long stroke (1") version.
    oh sinebar, that should be more accurate. what i ve used is bevel protractor. i indicated the bevel protractor, which was quite easy.
    Sent from my LGM-K120L using Tapatalk
    Aug 2011
    Central Virginia, USA
    you don't need a fancy protractor or DRO- just put some blue on the inside of the bore, insert the collet lightly with a piece of bar stock in it, and spin the collet. If the blue wipes evenly, your angle is good. If not, adjust compound and try again.
    allan
    one way to get tapers dead on is turn a male part, set it up on sine bar, indicate it, semi loosen the compound, tap tap tap gently with a brass hammer and try again. It's easier than it sounds and the basic way to get perfect tapers with basic measuring equipment.
    May 2015
    Somerset UK
    Seems like far too much bother, why not just bore out the 8.1mm hole and press in a bush and finish bore to 7.98mm.
