Results 11 to 20 of 34
Thread: Spring floods!
    Dec 2008
    Kendal, On
    Yikes. Here's hoping it doesn't crest your shop floor. Looks like you have a couple inches to play with still, but there's still a lot of snow in the background.......
    any chance at sandbagging it?
    Jan 2007
    Minnesoa
    Hi,
    No real melt here yet. Still too cold. But there is concern that our township road will wash out when it does melt. It often goes underwater during the melt because it's only a bit higher than the lake it drains into. And a couple 1000 acres drains through the area. So I'm hoping for a slow melt this year.
    Oct 2005
    British Columbia
    Hope all goes well for you Andy. Can you sandbag around the entrance, dig a small sump and maybe place a pump there as a last defense before it goes any further?
    Pray for frost and a slow melt.
    Feb 2014
    There is nowhere to dig too. It is high because the snow is/was melting. It is a bit cooler today so that helps. This is the highest I have seen it here in all my years. I have one small pump going (electric). I will see if it starts to go down here. If not I may break out the gas pump(s).
    Maybe you could use that plow truck and some of that snow to dam up around the shop door? If it's packed well, that might hold the water off for a day or two.
    Mar 2008
    Kent, U.K.
    Ah, sorry I misunderstood. When you said you were at the highest elevation around but with a bowl-shaped yard I figured there must be somewhere to trench to for a run-off.
    Monarch 10EE 1942
  6. #16
    Dec 2017
    Bemidji, MN
    Those of you along the Mississippi corridor should be worried because in northern Minnesota the snow has not started to melt enough to run off but there is more snow than I have seen and the water content is also quite high. The 10 day forecast shows the temperature to be rising each of the 10 days which means the runoff will be quite quick. If you live on low ground, this might be the year to move anything with wheels to higher ground.
  7. #17
    Stevens Point, WI
    Quote Originally Posted by Peter. View Post
    You understood right, we are at the highest point in our town but with a bowl in the backyard (like a mini volcano). But there is no way we could dig any trench out to anywhere as it is roads/parking lot/neighbors land around us.
    Quote Originally Posted by RMinMN View Post
    Same here with northern (and even here yet) WI. Tons of snow up north just waiting to come down the Wi river and dump into the mississippi. Good advise to our southern buddies to get ready now!
    I had the small electric pump running all day and night. Water has went down around 4". I think we may survive!
    Ct
    If you don't/can't get a drain off your property (check with the local government, you could tie into their road drains) then fill in the low spots on your property.
    You are not required by law to establish or maintain catchment ponds on your property.
    Rain falls everywhere and drains where it will.
    Len
  9. #19
    Stevens Point, WI
    Quote Originally Posted by QSIMDO View Post
    I'm not to worried about it. Like I mentioned I've lived here for around 40 years now and this is the first time it has been this high. Unless global warming makes this a trend.
    Oct 2005
    British Columbia
    Don't let your guard down just yet. Seems like around here the once in a hundred year fire/flood is more like every five years.
