Results 1 to 5 of 5
Thread: Ugrading To An ATC Spindle - Quick Change
    Jan 2014
    In the desert
    Default Ugrading To An ATC Spindle - Quick Change
    PART 1 of ??
    Dec 2008
    Kendal, On
    I bet that air outlet is for a breather. The inlet air to the drawbar has to go somewhere. Those ISO 20 toolholders are cute little guys.
    Jan 2014
    In the desert
    Near as I can tell no air vents out that hole from anywhere. I showed testing for that in the vid. When you heard the air release from the tool change that was me pulling the air nozzle out of the tube.
    Yeah, they are cute little tool holders. I'm sure looking forward to using them.
    Jan 2014
    In the desert
    Ok, after more time reading and researching and finally getting a copy of the manual it looks like its a piston return on the other side of a dual acting air cylinder. The air cylinder may have a return spring also, and of course the draw bar has to have some sort of springs which push back when the air is let of. Looks like I need a 2 position 5 port changeover valve.
    Jan 2014
    In the desert
    Part 2
