Page 1 of 14 12311 ... LastLast
Results 1 to 10 of 140
Thread: Sideshaft i.c. Horizontal Engine
    Mar 2008
    Barrie, Ontario, Canada
    Default Sideshaft i.c. Horizontal Engine
    You fellows may remember---When I was chasing down helical gears for the sideshaft hit and miss engine I built, I bought a pair with 2:1 ratio off Ebay for $12.00 which is about $90 less than I paid for a set made in USA. I used the made in USA gears from Debolt to build my engine, but had the Ebay Chinese gears left over. I watched a YouTube video of an Edgar Westbury engine called the "Centaur" and was very impressed with the valve and sideshaft arrangement on it. Grandma was right--Idle hands truly are the devil's workshop. I was bored this week, so I've been messing around designing another sideshaft engine which uses the Chinese helical gears, and a valve arrangement similar to the Centaur engine. It's not a hit and miss engine--just a 4 cycle open crankshaft engine with a throttled carburetor. I might never build it, but it is interesting.
    Mar 2008
    The engine has a 1" bore and a 1.375" stroke and is air cooled. I will probably design a fan on the side opposite from the sideshaft and drive it with an o-ring drive belt from the crankshaft.
    Apr 2009
    Brian, we all hope you will build it and be very satisfied with the outcome!
    john
    Mar 2008
    The main chassis of the engine is interesting. It is hogged out of a block of 2" thick 6061 aluminum.
    Mar 2008
    This is a link to a working model of the Centaur engine.
    https://www.youtube.com/watch?time_c...&v=8Am5H2aPmyc
    Sep 2012
    Wellington county Ontario Canada
    I think we see this thing purring away on your bench in a few weeks...
    Jon
    Mar 2008
    Jon--You could very well be right. I am seventy two years old and in reasonably good health, but I am not coping really well with retirement. When I don't have any "real" design work to do, I tend to fill up my life with building small engines to make the days go by.---Brian
    Feb 2016
    Edmonton, Alberta, Canada
    Is that larger gear going to fit in that spot? It looks like it may interfere with the flywheel on that side...
    Mar 2008
    Quote Originally Posted by dave_r View Post
    It will fit---barely.--See that big slot cut in the side of the main frame in post #4.--that is in there to accommodate the large gear.
    Mar 2008
    Of course, if you have an air cooled cylinder, it's always a good idea to have a cooling fan. I dug around in my "odds and ends" drawer and found the perfect size plastic fan. I also dug around in my aluminum box and found a scrap of 2" aluminum large enough to make the main engine body from, and a piece of 3/4" material large enough to make a base. I spent a couple of hours this morning putting in all of the tapped holes and clearance holes to put this thing together.
