Results 1 to 10 of 21
Thread: Trepan a big washer?
    Nov 2015
    Sydney
    Default Trepan a big washer?
    I need to make seven large washer-like disks. About 230mm (9") OD and 150mm (6") ID. Material is 3mm (1/8") 316 stainless.
    I was thinking of using the lathe faceplate or a rotary table, but then I thought about trepanning it on the mill as it would be easier to set up. I've got a slightly overbuilt indicator holder for a fly cutter head that I could use. The indicator holder is 1" square.
    So what do you suggest? Faceplate, rotary table or trepan? Carbide or HSS? I've got a carbide face grooving tool that I could use.
    Jul 2006
    Germany
    Faceplate.
    Using measurement instrument holders for machining is a total no-go, even if it's overbuilt. Just the idea!
    Helsinki, Finland, Europe
    Second vote for faceplate. Would consider trepanning 230mm stainless disk on a mill only if your mill is super heavy monster(at least the tool taper is promising)
    Nov 2015
    Sydney
    Mill is one of these https://www.machineryhouse.com.au/M585D
    Not a super heavy monster, but probably more rigid than a BP as the head doesn't nod. Weighs 1.7 tonnes.
    Jan 2007
    Minnesoa
    Hi,
    Yeah, I would do a face plate too. Your mill is a bit better than a Bridgeport, but it's still going to be pissed at you.
    Chilliwack, B.C.
    No, I don't think that machine is going to be good enough Seriously, I'd have some reservations about trepanning at that size in stainless to begin with. I'm in the faceplate camp- I'd probably band saw them out roughly, then mount on a faceplate and turn out the center disc, then re-mount using the center hole so you can turn the OD. Just my thoughts on it-
    Kirkland, Washington
    I would rough it out first with a plasma cutter and use the mill to drill a center hole. Then I'd put on the lathe faceplate and put the part against a piece of MDF against the faceplate with pieces of kraft paper between. Hold it there with a live center in the tailstock. Now you can either turn it to size or trepan, your choice. Either way you can dig the cutter right into the MDF, no damage to the faceplate or part.
    After you get the OD finished you can put the part in a 4-jaw carefully and trepan the inner hole.
    metalmagpie
    Nov 2015
    Sydney
    Thanks all. No bandsaw or plasma cutter here. Any concerns about only clamping it from the outside, cutting the ID, then cutting the OD? The minimum distance between slots is about 200 mm (bigger than the ID of the part).
    Sep 2015
    NW Illinois
    I would go with the faceplate. Clamp the blank with some sacrificial material behind it. Grind a narrow trepanning tool.You want a lead angle on the tip of the tool so the side facing the part breaks through first. Cut the hole first, then the OD. Be prepared for some excitement when the tip of the tool breaks through.
    You might consider fastening the blank to the sacrificial material with glue or double sided tape. That could prevent material from shifting when the tool breaks through. Less excitement that way.
    edit
    Better yet screw the sheet to the backing inside the 6" dia. Several screws. Cut the outside first, then the inside. You might want to consider drilling and tapping some holes in the faceplate inside thr 6" dia. to better grip the sheet.
    Mar 2012
    Why not rotab on the mill with a backer board? Sounds real boring to me compared to the potential "excitement" of the other methods.
