Page 5 of 5 FirstFirst ... 345
Results 41 to 45 of 45
Thread: Deep thoughts...metric threading
  1. #41
    Feb 2012
    Metcalfe, Ontario, Canada
    Quote Originally Posted by rickyb View Post
    And if your lathe, like my Logan, doesn't have a reverse?
    Reverse by pulling the belt. If you can't do that, use an open-end wrench on the chuck jaws. Or make a spindle crank. Better yet, have a reverse, by one means or another.
  2. #42
    Mar 2011
    Troy, Mi
    Quote Originally Posted by cameron View Post
    Then your way to go method isn't much of a way to go for me. I've tried this and it is untenable. Even with an electric drill jammed into back end of the spindle is a pita. I like Paul's crank idea andhopefuldave's drum switch.
    Threaded spindle limits my versatility of reverse unless I lock the chuck with a set screw of sorts. I now have a Magnetec 1 hp D.C. Motor and a Camco controller on the Logan. It is the single direction controller and can stop the spindle instantly. So much so that I spun a chuck off one time. I have to shut the power off and not use stop switch with a heavy chuck. I can easily get down to 2-3 rpm with this setup at near full hp. This slow speed and the brake will get me to a shoulder. Just need to add a switch to reverse the motor wiring.
  3. #43
    Jan 2004
    Missouri
    Quote Originally Posted by Yondering View Post
    The "doesn't count" thing seems silly to me. Try doing the same thing without a thread dial; it's possible but a lot more difficult.
    As far as "just backing up" - disengaging the half nut allows you to thread up to a shoulder on lathes that don't have a brake (which most home shop lathes don't, look at the name of this forum). If you can't thread up to a shoulder, in most cases I use anyway, you can't thread at all.
    If you have to work to a customer print that calls for thread up "tight to" a shoulder, well OK. Feel free to charge the customer for a silly requirement that costs more to do.
    But if you are designing your own part, or are able to modify, then a small relief groove makes all the difference. It may be a better, stronger design as well.
    I rarely see a thread up to a shoulder anymore, they generally have relief grooves, because even in industry, it is easier and cheaper not to thread up tight to a shoulder, and it can be a poor design from a strength perspective.
    Feb 2014
    Yet another facepalm for Jerry.
    Of course there's a relief groove. If you thread at any reasonable speed above elderly walking pace and don't have a huge relief groove, you'll need to disengage the half nuts when threading up to a shoulder. I know you know this if you do any actual lathe threading, but of course you wanted something to argue about, again.
  5. #45
    Dec 2008
    Kendal, On
    If a part is designed for mass production it's cheaper to make it without the relief groove (just another feature that doesn't need to be there), as it will be done in a CNC and the machine doesn't care it there's a relief groove or not.
