Results 1 to 10 of 16
Thread: What type of abrasive belts for steel?
    Atlanta, GA, USA
    Default What type of abrasive belts for steel?
    I have been using the abrasive belts made for wood on my old 6" x 48" Delta floor-mounted belt sander to occasionally work steel and iron. They do the job but soon wear out, plus they pretty much ruin a belt for wood.
    I am wondering if there are better belts made for steel and iron that last a long time. Any thoughts from you guys? And where do you buy them?
    Helsinki, Finland, Europe
    3M cubitron, Norton Blaze or other ceramic belts from other makes. Zirkonia belt if you want mid-range price/performance
    Jan 2009
    Central Ohio
    ^^^ yes... good belts cost a lot more but are well worth it.
    Sep 2011
    Langley, British Columbia
    The blue Zirconia belts are the best value for your money. We run a couple different brands from
    Europe--can't remember the name offhand but they're very good. We've tried the 3M Cubitron stuff
    in sanding discs, grinding wheels and sanding belts and the extra cost is't worth it--they just don't
    last that much longer. And, as far as I'm concerned, you should stay away from Norton. In 40+ years
    of running our shop I never found a Norton product that I liked or that performed as well as the
    European offerings...
    Keith
    __________________________
    Atlanta, GA, USA
    Thanks guys! Blue Zirconia belts! I am going to search for them now!
    Sep 2011
    Quote Originally Posted by Planeman41 View Post
    And if you're going to run the Zirconia belts--which I think is a very wise choice--run 24 or 36 grit if you really want
    to remove some material. Don't mess around with 60 or 80 or 100 grit unless you are truly trying to get a super
    fine finish. A 36 grit belt will soften up pretty quick as the edge wears off the abrasive. We just keep a few of the
    older belts around for those times when we want a finer surface finish...
    Keith
    Sep 2006
    Southwestern Ontario, Canada
    Defiantly these ones. I have some on a small belt sander in my home shop, I don't remember the brand. There is a tear down the middle of one which hasn't affected its operation in the least. It's been there for many months now and since I'm retired and cheap I haven't changed it. Still going strong. Still cuts very well.
    Stevens Point, WI
    Where is the best place to get belts from?
    May 2007
    Camillus, NY (Syracuse)
    I’ve found that the 50 grit seems to be a great choice, aggressive enough to cut, but fine enough, where I do not have to change belts to get a good finish. I have been using Carborundum 2” x 48” 50 grit belts on my Jancy RaduisMaster, for about 8+ yrs, at about 4000 fpm, they work great.
    jack
    Atlanta, GA, USA
    "Run 24 or 36 grit if you really want to remove some material"
    Thanks for the tip! I looked into the Zirconia belts but haven't ordered yet. Was thinking about 100 grit but will follow your suggestion when I order. I usually buy coarser wood abrasive belts to be able to use the worn down belts for finer work. I should have been thinking this way when I was looking.
    Ain't this website a great place!
